782 May have bit the dust.
10 replies to this topic
#1 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted August 23, 2016 - 12:55 PM
My dad was using his 782 to take hay to the cows this morning when he noticed smoke coming from the transmission followed by a bang and oil being pushed out of the dipstick and the tractor wouldn't move, I am pretty sure the bang was the driveshaft letting loose.  Here are some pics of the aftermath, first two are of the driveshaft/pump area, third is of the dipstick, and the fourth is the back compartment under the seat, any idea what may have happened?
  • chieffan said thank you
#2 EricFromPa ONLINE
EricFromPa
  • 3,523 Thanks
  • 3,070 posts
Posted August 23, 2016 - 01:39 PM
Where did the driveshaft let loose?did it harm the input shaft on the pump?Are you going to put another driveshaft in her and save it?
Drain the fluid and install a GOOD Hydraulic oil filter and take the fenders off and get all that grease and dirt blasted off so it can run cooler.
Might of been just a collapsed filter.Don't ever use a Fram filter or any brand of regular Oil filter for hydraulics.They are to restricted and most times the element inside will constrict and completely stop up.
#3 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted August 23, 2016 - 02:00 PM
The driveshaft broke between the rag joint and where it attaches to the pump, the filter is a filter that is the exact part number and was purchased from the local IH dealer, what would have caused the oil to come out of the dipstick, the oil is HY-Tran, and was changed this spring. My dad is convinced the axle went because of the oil that was pushed out, I'm not so sure.
#4 MiCarl ONLINE
MiCarl
  • 1,913 Thanks
  • 1,020 posts
Posted August 23, 2016 - 03:59 PM
I don't know anything about your drive but I wonder if the transmission was failing and started to boil the oil just before it seized up?  Then the shaft broke because the transmission wouldn't turn.
#5 aagitch OFFLINE
aagitch
  • 107 Thanks
  • 83 posts
Posted August 23, 2016 - 07:25 PM
It looks like the coupler that connects the driveshaft to the pump took a dump.  It's well worth the time and money if the rest of the 782 is in shape.  You'll have to make sure it didn't damage the hyd lines attached to the pump.  I'd replace what needs replaced, top off the hyd fluid, put new filter on if damaged, and fire it up and see whatcha ya got.
#6 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted August 23, 2016 - 10:12 PM
The pump still turns without issue.
That's exactly where it broke, could also explain the smoke if it slipped or rubbed before it let go. It didn't snap as if it locked up, but broke a chunk out of the side, the lines are damaged, how bad, I don't know.  The only thing that I can't easily explain is the fluid loss.  Gonna retrieve it with the pick up and trailer tomorrow, my next step will be to remove the filter, cut it open and inspect it for metal fragments, I'm not so sure that something locked up, time will tell.
#7 shorty ONLINE
shorty
  • 5,277 Thanks
  • 5,164 posts
Posted August 24, 2016 - 04:30 AM
If the lines got crushed, wouldn't that give a surge in fluid going somewhere.
#8 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted August 24, 2016 - 06:04 AM
I think you're on to something, not going to get to it today, gotta get some hay in before it rains tomorrow.
#9 shorty ONLINE
shorty
  • 5,277 Thanks
  • 5,164 posts
Posted August 24, 2016 - 08:17 PM
Talk about carnage in a heartbeat. Sure doesn't take long when the driveshaft starts flopping around. I had that happen to my Ariens. A bunch of mangled parts.
#10 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted August 24, 2016 - 09:51 PM
Yeah it made a mess for sure, may end up going to a local shop that is better equipped to deal with it, I already have a lot on my plate.  I had heard of this happening previously, hoped I'd never see it first hand, didn't do much of anything with it today, too busy with other stuff.
  • shorty said thank you
#11 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted September 18, 2016 - 08:21 PM
Picked the tractor up today, works good, ended up being a complete drive shaft transplant from a parts machine.
  • olcowhand and CRFarnsworth have said thanks
