Sold
1967 Ford 80 - $375 (New Freedom PA)
2 replies to this topic
#1 VintageIronCollector ONLINE
    Immersed in Tractors
  • 1,282 Thanks
  • 1,783 posts
Posted August 21, 2016 - 10:13 AM
New:
Air filter
Fuel line and shut off
Spark Plug
Trans Oil
Battery
Battery Cover(not on in picture)
Hood decals(included for new owner to decide if they want to put on)
Needs:
Smokes badly and has 120 psi compression so it seems like the oil piston ring isn't scraping enough off the walls of the cylinder. NOS kohler rings on ebay right now run about $20-30 and you'll need an oil pan gasket too which is about $6-8 NOS kohler.
Right side screen mesh in front of dash
Tractor drives good and charging system works good and runs smooth besides the smoke of course. The original PTO was missing parts so I got a triple pulley off a Ford T-800. I put new front valve stems in too because originals were rotted off and the right tire holds pressure but the left side will get soft after a few days but doesn't go flat or get very low it stops leaking after it gets soft. Rear tires have no visible cracks in them on the side from what I can tell. Seat ain't in perfect shape but it's decent enough for the condition the tractor is in. Any questions I'll try to answer best I can. Asking $375 obo. Thanks for looking
  • Traill95 said thank you
#2 EricFromPa ONLINE
EricFromPa
  • 2,427 Thanks
  • 2,415 posts
Posted August 21, 2016 - 02:44 PM
Could have worn Valve guides if it has that much compression and still smokes.
$20.50 shipped
http://www.ebay.com/...p-/121079637930
  • VintageIronCollector said thank you
#3 VintageIronCollector ONLINE
  • 1,282 Thanks
  • 1,783 posts
Posted August 26, 2016 - 02:55 PM
Sold. Thanks
Also tagged with one or more of these keywords: Sold
