T-Minus 3 days
44 replies to this topic
#31 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 523 Thanks
  • 473 posts
Posted April 10, 2010 - 09:16 PM
More pics of the 920 with the deck cleaned up and mounted
#32 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 523 Thanks
  • 473 posts
Posted April 12, 2010 - 09:19 PM
Well its time for the 920 to do a little work. Got the tiller mounted and got my belt and idler issues figured out hopefully. Did a little test area and found out this tractor handles that tiller with out a problem.
#33 mjodrey OFFLINE
Posted April 13, 2010 - 06:02 PM
That is a real workhorse looking tractor,I like it.
#34 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 523 Thanks
  • 473 posts
Posted April 13, 2010 - 08:19 PM
She got a little fatter today, Tossed another set of weights on the rear and put some front wheel weights on too.
#35 Bolens 1000 ONLINE
  • 14,902 Thanks
  • 18,100 posts
Posted April 14, 2010 - 05:22 AM
Looking good! :thumbs:
#36 olcowhand ONLINE
  • 40,349 Thanks
  • 31,170 posts
Posted April 14, 2010 - 08:34 AM
Fluid fill those rears too. You'll stick to the ground like hot tar!
#37 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 523 Thanks
  • 473 posts
Posted April 14, 2010 - 04:10 PM
So what are people using to fluid fill the rears nowadays, and would I have to tube the tires?
#38 olcowhand ONLINE
  • 40,349 Thanks
  • 31,170 posts
Posted April 14, 2010 - 04:18 PM
No need for tubes. A few different things are commonly used....camper water line antifreeze, regular motor antifreeze mix, winter formula windshield washer fluid, or 20% alcohol 80% water mix. I get the alcohol at a tire center. If tire leaks, there's no fire danger due to dilution ratio. In my one tractor with alcohol, I also added some regular engine antifreeze for the corrosion inhibitors.
#39 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 523 Thanks
  • 473 posts
Posted April 14, 2010 - 04:36 PM
So how much weight could I expect to see by filling the rears?
What does the alcohol do in the mix?
#40 olcowhand ONLINE
  • 40,349 Thanks
  • 31,170 posts
Posted April 14, 2010 - 05:27 PM
Not sure how much the 10.50x12's will hold, but likely around 7 to 9 gallons per tire, so anywhere from 56 to 72lbs per wheel. The alcohol just prevents freezing....reason I added a little antifreeze was just to further prevent corrosion. Just take wheels off, then pop a bead on one side...then simply push bead down away from rim far enough to pour in the chosen liquid...air up & done. Filling up to the tire bead edge is just right....leaving enough air space.
Edited by olcowhand, April 15, 2010 - 09:06 PM.
#41 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 523 Thanks
  • 473 posts
Posted April 15, 2010 - 08:59 PM
Thanks Olcow.
Well got me a sleeve hitch fabbed up for it now.
#42 olcowhand ONLINE
  • 40,349 Thanks
  • 31,170 posts
Posted April 15, 2010 - 09:08 PM
Your lift looks great! Nothin like the old saying...."Get-R-Done"!:thumbs:
#43 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 523 Thanks
  • 473 posts
Posted April 15, 2010 - 09:41 PM
Thanks, still gotta get somthing figured out instead of the lift chain, I'll probly end up useing a turn buckle of some sort for adjustability.
I got the plans from the "Other Site" but I'll probly dig em up again and post em over here for anyone who wants them.
#44 olcowhand ONLINE
  • 40,349 Thanks
  • 31,170 posts
Posted April 15, 2010 - 10:10 PM
The chain is a good way....works as a "float" to allow implement to follow the ground without being tied to tractor. If rigid, when plowing and tractor goes over high spots up front, the plow will be forced down & lose traction, or when front wheels drop, the plow lifts.
#45 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 523 Thanks
  • 473 posts
Posted April 15, 2010 - 10:43 PM
ON these Allis and Simplicitys the rear and center lift is operated via a cable so I would still have a float. I sure wish I could have down pressure on the center and rear though
