Vote for Tractor of the Month
simplicity buzz saw?
8 replies to this topic
#1 Dan O ONLINE
Dan O
  • 73 Thanks
  • 29 posts
Posted August 19, 2016 - 06:08 PM
Not a lot of safety features there, you could loose a limb pretty quick.
Is this thing looks homemade to me, was this actually a factory option?
I think it would be perfect for a Mad Max Tractor.
https://milwaukee.cr...5698392379.html
$200
Random Lake, WI. (about 40 minutes north of Milwaukee)
#2 CanadianHobbyFarmer ONLINE
CanadianHobbyFarmer
  • 966 Thanks
  • 609 posts
Posted August 19, 2016 - 06:44 PM
I have no idea if that is a factory attachment or not. I have seen a few buzz saws though and have never really seen much of anything on them for safety features. I'm not sure what you could put on one to make it safer. That is likely why you don't see them being made any more.
Jim
#3 drbish ONLINE
drbish
    Collecter
  • 1,256 Thanks
  • 1,195 posts
Posted August 19, 2016 - 06:59 PM
Simplicity and many others made them for the 2 wheel tractors.
Edited by drbish, August 19, 2016 - 07:09 PM.
  • Alc, boyscout862 and Dan O have said thanks
#4 Mtypython ONLINE
Mtypython
  • 270 Thanks
  • 299 posts
Posted August 19, 2016 - 07:22 PM
Cord wood saw,firewood pre osha
#5 ckjakline ONLINE
ckjakline
  • 1,103 Thanks
  • 1,107 posts
Posted August 19, 2016 - 08:28 PM
I have a saw that looks like that one. I do believe it's simplicity.
  • Dan O said thank you
#6 Alc ONLINE
  • 5,678 Thanks
  • 6,756 posts
Posted August 19, 2016 - 10:06 PM
I wonder if all the pieces needed to run it are there . My DB has a special engine pulley and jack-shaft that were part of the attachment .
#7 chieffan OFFLINE
  • 6,372 Thanks
  • 4,607 posts
Posted August 20, 2016 - 07:17 AM
I have used a few different Buzz Saws and owned one at one time.  They all cut on the right side of the table.  This one cuts on the left.  No table return spring either so don't think it is all there.  Definitely need a blade guard.  Probably a stationary type saw that stakes to the ground and used a belt pulley on the tractor to drive the saw.  That is the way mine was set up and worked good with a sharp blade.
  • boyscout862 and Dan O have said thanks
#8 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,169 Thanks
  • 5,762 posts
Posted August 20, 2016 - 07:38 AM
Used one of those for many years mounted on the front of a WD45
#9 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,676 Thanks
  • 1,347 posts
Posted August 20, 2016 - 08:30 AM
Jim
I think safety has taken the place of common sense.
  • CanadianHobbyFarmer and Dan O have said thanks
