So,,, tried plowing again today.
29 replies to this topic
#16 KennyP ONLINE
  • 38,417 Thanks
  • 45,945 posts
Posted August 19, 2016 - 05:11 PM
Have you put the left side of the tractor up on blocks and set the plow up that way? If the yoke it wrong, the plow will not sit flat to ground. Take a look at what I did here.
  • Cvans and propane1 have said thanks
#17 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted August 19, 2016 - 07:04 PM
If I am correct, take the hitch off the front of the plow and turn it 180° (white piece). Mine was the same way and I could not get it to plow right. Did the turn over and it got real nice after that. Some tractors will work with that as it is, but my Ford would not!
There is something like a 15* "twist" on this piece so that when the right wheels are in the furrow, the plow sits level (side to side).
  • propane1 said thank you
#18 propane1 ONLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted August 19, 2016 - 07:55 PM
No adjustment on a sleeve hitch , which mine has, for levelling the plow level, to do your crown, then releveling, when the wheels are in the furrow. A 3 point hitch has that adjustment.
Noel.
#19 DH1 ONLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted August 19, 2016 - 08:01 PM
In the BRINLY plow manual it say's if you plow sod expect to have problems.
  • MH81 and propane1 have said thanks
#20 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted August 20, 2016 - 07:03 PM
Noel, your front hitch is upside down as Kenny said.I had to loose the Colter as well because it didn't want to penetrate the soil.
I too have a sleeve hitch with the same plow.
One issue that causes the roll to fall back is too thin a slice. Flipping the hitch will give you a few more inches of bite.
As far as getting a crown? Going to be a real challenge with a sleeve hitch but may be do-able? Not sure as I have never tried it.
I might have to give it a try as the fields done correctly are so awsome looking!
  • KennyP and propane1 have said thanks
#21 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted August 23, 2016 - 08:26 AM
Noel, how are you making out with plow and that double crown? Whoo doggy is that difficult to do with a light tractor in sod!
I don't have the gage wheel like you do (wished I did) I could not roll the first light pass over unless the plow was full depth or it would steer me where ever it wanted.. need some serious weight up front.. and in the rear as the sod would slide you sideways if it offered up any resistance but this was only when trying to get that double crown. If I just started at one side and worked my way to the other it went fine?
#22 propane1 ONLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted August 23, 2016 - 10:25 AM
Have not got back to it yet. Am going to try with the ferguson farm tractor tomorrow. I want to papractice a bit before the plow match this weekend. Will try the garden tractor in lighter sod/soil maybe this weekend. Will post pictures , if the plowing is any good. Thanks for your interest.
Noel
  • Cvans said thank you
#23 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted August 24, 2016 - 02:44 PM
How's papractice going? :poke:
#24 propane1 ONLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted August 24, 2016 - 03:08 PM
Sorry, can't spell, I guess.
Noel
#25 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted August 24, 2016 - 03:10 PM
HAHAHA!!!!
#26 propane1 ONLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted August 24, 2016 - 03:23 PM
So, did a split crown, not sure if that's the correct name, I'm sure someone can correct me, and just a crown. First time I ever did a split crown. The plow is tilted so only the rear plow is used on the first furrow, then set back to crown setting. So I didn't do very well. But you maybe able to see what I did. Last picture is a crown, second last picture is a split crown.
Split crown, all sod is cut under the crown.
Crown, sod is flipped on top of uncut sod.
Noel
#27 KennyP ONLINE
  • 38,417 Thanks
  • 45,945 posts
Posted August 24, 2016 - 04:01 PM
I've never given much thought to all this! Guess us Okies are in the dark ages!
#28 MH81 OFFLINE
Posted August 25, 2016 - 06:50 AM
How deep is the Fergy going?
#29 propane1 ONLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted August 25, 2016 - 08:53 PM
About 5". They are 10"
Plows.
But, depending on the hills on the land, which are small, it will move the tractor up or down on the front , which will affect the depth of the plow
Noel.
Edited by propane1, August 25, 2016 - 08:56 PM.
#30 MH81 OFFLINE
Posted August 25, 2016 - 09:05 PM
Those look like the 2-14's we had. Must be the pic, but they look bigger than 10’s. What model are they?
Also, here is a page that has the Fergy setup. From '47
http://www.ntractorc...sages/6618.html
And another
http://www.ntractorc...sages/6570.html
