Golf Cart Motor
14 replies to this topic
#1 DanP OFFLINE
DanP
  • 324 Thanks
  • 485 posts
Posted August 19, 2016 - 01:09 PM
I am interested in a gas golf cart frame and motor for a project I want to build. If found this Harley Davidson cart. The owner says he had the motor rebuilt $600.00 and it ran fine for a while but now he has a hard time keeping it running and the only way it will run is with the choke full on. Not sure what was included in the rebuild. I have no idea if you can still get HD parts. Any idea what to look for as far as the choke thing. Maybe it has a Tecumseh carb on it  :rolling:  Here is a picture of it.
  • Traill95 and boyscout862 have said thanks
#2 tater195 OFFLINE
tater195
  • 2,197 Thanks
  • 1,412 posts
Posted August 19, 2016 - 01:21 PM
my guess would be a crapped up carb or the electric inline fuel pump
  • DanP, Traill95 and boyscout862 have said thanks
#3 Traill95 OFFLINE
Traill95
    Traill95
  • 1,848 Thanks
  • 1,013 posts
Posted August 19, 2016 - 01:41 PM
What he said.   :thumbs:
  • DanP said thank you
#4 tater195 OFFLINE
tater195
  • 2,197 Thanks
  • 1,412 posts
Posted August 19, 2016 - 01:50 PM
I just noticed the old style fuel filter on the inlet to the fuel pump and the kinked fuel line going it to it. I would start there. that giant gas tank is probably full of stale water logged ethanol too
Edited by tater195, August 19, 2016 - 01:56 PM.
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted August 19, 2016 - 01:53 PM
Just a little kink
#6 MiCarl OFFLINE
MiCarl
  • 2,024 Thanks
  • 1,050 posts
Posted August 19, 2016 - 03:42 PM
I used to have one of those.  Mine was a 1980.  When I got it the governor was disconnected and it went like a bat out of hell.  I put the governor back on after the daughters rolled it.
I'd agree that your problem is carb/fuel system.  If you have the same carburetor I had it has an integral vacuum operated fuel pump - the thing is similar to a chain saw or weed whip.  That aftermarket electric pump raises all sorts of red flags.  The carburetor needs to be set up properly, order a rebuild kit and the service manual from the link in the next paragraph.
Parts are readily available for the engine/carburetor.  This guy has most everything: http://www.golfcartcare.com/.  I got a piston and rings from him when I rebuilt the top end and various other parts from time to time.
I had trouble with it being hard to start after sitting - the fuel line would drain back into the tank.  Turns out there is supposed to be a check valve in the tank on the fuel pick up.  It was a commodity item I ordered through my local small engine shop.
#7 MH81 OFFLINE
Posted August 19, 2016 - 06:40 PM
Two stroke, right? If the seals on the main bearings go, it'll start like that too.
#8 poncho62 OFFLINE
poncho62
  • 1,757 Thanks
  • 1,666 posts
Posted August 19, 2016 - 07:04 PM
Looks a lot like the engine in my EZ Go golf cart.........2 stroke that runs in both directions, no transmission.
I agree, its likely just the carb plugged up.
#9 jimmy G OFFLINE
jimmy G
  • 1,197 Thanks
  • 779 posts
Posted August 19, 2016 - 07:09 PM
I'd do a compression test, I helped a friend with one of those and it took rings to get enough pulse to run the carb right. the problem with running a golf cart like a go cart is the cooling air intake plugs in about 5 min.s and the rest of the day the kids drive it over heating, or every day if not cleaned constantly. I showed this to my friend and told him if he didn't keep it clean he could expect more of the same,he never had another problem with it and sold it after 11yr.s when his kids graduated. they are tuff golf carts and this is the only draw back to driving them in the semi-rough.if you find nothing wrong in the fuel system this could be the problem. penny penny
#10 EricFromPa ONLINE
EricFromPa
  • 3,659 Thanks
  • 3,115 posts
Posted August 19, 2016 - 07:10 PM
Just had one of those here to work on.That one is made by EZ-Go Should have the same Tillotson carb with Fuel pump.It might still have the Fuel pump plate and valves on the carb.I would advise you to remove it if your using an electric pump.
Here is what the carb looks like with the pump removed and just the Float diaphragm and plate installed.They used these carbs on alot of older Snowmobile engines to so parts are very asy to find if you just want to rebuild the original diaphragm pump.
WOW those carbs are CHEAP to just replace.
https://www.amazon.c...1/dp/B00O3MRATA
  • ducky, Gtractor, Alc and 2 others have said thanks
#11 MiCarl OFFLINE
MiCarl
  • 2,024 Thanks
  • 1,050 posts
Posted August 19, 2016 - 07:46 PM
Wow!  I probably paid that much for repair parts.
#12 MH81 OFFLINE
Posted August 20, 2016 - 06:37 AM
I have a Yamaha that's still in operation.
Had carb, CDI, and ring issues. It was a mess of little problems.
Here is a pic of the original rings and one new one I broke during installation.
It was a hard starter. Wanted choke like crazy... Had like 2 for compression.
#13 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted August 20, 2016 - 08:10 AM
Now we're talking more my speed since I work on golf cars for a living. Out here, those machines are a dime a dozen, non running $100-200 for it typically.
I have two left that were trade ins if you need any parts.
  • MH81 and DanP have said thanks
#14 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 10,465 Thanks
  • 5,768 posts
Posted August 20, 2016 - 10:05 AM
And it is usually the Clutch side of the crank..  If it sucks air the thing would lean out and burn the piston down in short order if ran hard.  What do the plugs look like?
#15 DanP OFFLINE
DanP
  • 324 Thanks
  • 485 posts
Posted August 22, 2016 - 08:07 AM
Thanks for all the help. I don't own this yet as I found it on craigslist and wanted to know what I needed to do before I bought it. I sent the owner a list of questions but he never responded. If he doesn't want to answer calls he should take it off the site. I found another one that the owner says needs new seals in it. Not sure if that is all that it needs.
