Gray Market Kubota lift problem
9 replies to this topic
#1 gacarr OFFLINE
gacarr
  • 2 Thanks
  • 2 posts
Posted August 19, 2016 - 06:12 AM
I have a Zen-noh 1802 and the lift has stopped working. The lift on this tractor doesn't work like a conventional 3 point, it is electric over hydraulic. It has 2 solenoids on top of the valve for the lift. Is anyone familiar with this type arrangement?
#2 boyscout862 ONLINE
  • 13,548 Thanks
  • 9,427 posts
Posted August 19, 2016 - 07:05 AM
Welcome to GTT. Someone that knows will be along in awhile. Some pics of the setup will probably help. As a general rule, most electical problems are a bad connection(often the ground). Good Luck, Rick
#3 MH81 OFFLINE
  • 29,978 Thanks
Posted August 19, 2016 - 07:11 AM
Welcome to GTTalk.
Hopefully a knowledgeable member will be able to answer your questions.
Pictures of the unit and the solenoids may help them help you.
#4 chieffan ONLINE
  • 11,330 Thanks
  • 7,104 posts
Posted August 19, 2016 - 07:16 AM
I have an old electric winch that is set up with 2 relays to reverse direction.  Relays went bad it was tossed.  Replaced the relays with Radio Shack relays and has worked for about 5 years that way.  Power trim & tilt on the older marine out drives used a similar set up, electric over hydraulic.  Your problem is probably just a relay not making contact.
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted August 19, 2016 - 08:58 AM
:welcometogttalk: :camera:
  • chieffan said thank you
#6 MiCarl ONLINE
MiCarl
  • 2,206 Thanks
  • 1,122 posts
Posted August 19, 2016 - 09:01 AM
I'll chime in too.
I've also got a winch with the 2 relay set up.  Yours should be the same except it's working a pump motor rather than a winch motor.
The Chinese relays in it only last about a year of light use.  I haven't been able to find a quality replacement.
#7 chieffan ONLINE
  • 11,330 Thanks
  • 7,104 posts
Posted August 19, 2016 - 10:12 AM
I'll chime in too.
The last ones I bought was RS, probably Chinese all right.  After a couple years I have to smack one once in a while.  Check with  www.allelectronics.com  They may have one.  I haven't look yet.
#8 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted August 19, 2016 - 10:19 AM
I've always replaced those type solenoids with one from an older Ford starter
#9 ducky ONLINE
  • 1,989 Thanks
  • 4,108 posts
Posted August 19, 2016 - 11:14 AM
Here is a good reversing relay if that is what you need.
http://www.blazenaut...r_Windlass.html
Do you have to change the motor rotation?
#10 gacarr OFFLINE
gacarr
  • 2 Thanks
  • 2 posts
Posted August 23, 2016 - 08:17 AM
Found the problem. It had a loose connection on one of the pin connectors.
  • olcowhand and Cvans have said thanks
