Massey ferguson 12 hydro disconnect mechanism?
#1
OFFLINE
Posted August 18, 2016 - 07:51 PM
I tried looking in the massey ferguson 12 parts book, nothing...
Does anyone know where it is?
Thanks!
#2
OFFLINE
Posted August 18, 2016 - 08:09 PM
It is up under the footrest and seat pan area from the right side sitting on the tractor. It is a shaft that comes out of the hydro pump with a roll pin in it. The roll pin should be aligned vertically for both driving and free wheeling. The roll pin is offset to one side a little bit. The side that sticks out more needs to be down for free wheel and up for driving. I "think" that is right, I got rid of my 12H this spring and now cannot remember which is which. Correct me if I am wrong guys.
- MH81, Alc, Sawdust and 1 other said thanks
#3
ONLINE
I am sure the guys will be in soon to answer your question.
Noel
- Greasy6020 said thank you
#4
OFFLINE
Posted August 18, 2016 - 08:12 PM
- Sawdust and Greasy6020 have said thanks
#5
OFFLINE
Posted August 18, 2016 - 10:57 PM
#6
OFFLINE
Posted August 18, 2016 - 11:50 PM
- ducky and Greasy6020 have said thanks
#7
OFFLINE
Posted August 20, 2016 - 10:21 AM
Good score,if you lay on your back looking up at the front left side of tranny,you should notice a T handle.just turn it till you can roll the tractor. Can't remember which direction or how many turns off hand now. Good luck
Starting to look like I'll need the good luck...
#8
OFFLINE
#9
OFFLINE
Posted August 20, 2016 - 12:39 PM
I figured it out, I had it disengaged, younger brother didn't have the weight to put power to the ground... had to get 3 people to push it.Lol. Here is a pic to help
Moved it though!
Edited by Greasy6020, August 20, 2016 - 12:39 PM.
- limebuzz said thank you
#10
OFFLINE
Posted August 28, 2016 - 11:20 PM
If everything is working properly with your freewheel valve, these machines will freewheel fairly easily (as long as the tires are up). It shouldn't require 3 people to move it.
#11
OFFLINE
Posted September 27, 2016 - 08:11 PM
Tires are kinda flattish... I would have moved it by myself, had they not volunteered their help.
