Holy cow, look at this plowing !
17 replies to this topic
#16 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted August 19, 2016 - 10:10 AM
Try adding a 2" x 6" extension to the moldboard.
Like this.
They work great for me.
  • MH81 and propane1 have said thanks
#17 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted August 19, 2016 - 10:12 AM
After reading about plowing competion judging... whooo boy! Are you in for a schoolin..The results are seriously gorgeous when done correctly. I'm not sure soil conditions will warrant perfect results. If it's as dry up there as it is here.. you will pull roots out instead of cutting them off thus leaving trash on top. The whole objective to plowing is to bury all the weeds and trash and refresh the top soil for seed.
You may need to roll the plow more to the furrow side so it forces the sod over. I had this problem with one of my plows when I couldn't make a deep enough cut in a fresh plot.
#18 olds45512 OFFLINE
olds45512
  • 1,339 Thanks
  • 677 posts
Posted August 20, 2016 - 07:42 PM
To go along with you other thread, if your not getting good rollover it's because your not taking a big enough cut. If you flip the yoke and go off the center hole you should be good to go.
  • KennyP and propane1 have said thanks
