Need some help, will they fit?
14 replies to this topic
#1 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted August 18, 2016 - 12:57 PM
I have a chance to get a tiller and snow blower for my Wheelhorse but I don't know if they will work on either of them.  The tags are pretty messed up but I'll give it a shot.
Tiller: T121147?
Blower: 26117?
Either of these look like good numbers?
Tractors are a 2003 315-8 and a Raider 14.
#2 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted August 18, 2016 - 01:50 PM
After looking at the picture again, the "T" in the tiller number could be a 7 if that helps.
#3 case442 OFFLINE
case442
  • 693 Thanks
  • 423 posts
Posted August 18, 2016 - 02:09 PM
They came off a bronco 14 Jeff
#4 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted August 18, 2016 - 02:46 PM
Well maybe that will help someone help me. Thanks.
#5 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,016 Thanks
  • 9,645 posts
Posted August 18, 2016 - 03:46 PM
Just about anything on a C series tractor will interchange from 1973 on. That's the beauty of a Wheel Horse. Make sure you have all the accessory parts to hook them up. It's really expensive to buy the mule drives for the tiller. . .    or the lift rod and flag for the blower.
  • David Brown and Sawdust have said thanks
#6 GWest OFFLINE
GWest
  • 540 Thanks
  • 495 posts
Posted August 18, 2016 - 04:11 PM
Tiller may be this one
http://www.wheelhors...1-om-ipl-snpdf/
At the very minimum the lift hardware is different for the 315-8
Garry
#7 GWest OFFLINE
GWest
  • 540 Thanks
  • 495 posts
Posted August 19, 2016 - 05:22 AM
If the 26117 is a serial number it may be
http://www.wheelhors...-om-tipl-snpdf/
A 1985 model has a serial number 26147.
Garry
#8 MH81 OFFLINE
Posted August 19, 2016 - 06:48 AM
Can you shoot a couple pics our way?
  • David Brown said thank you
#9 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,016 Thanks
  • 9,645 posts
Posted August 19, 2016 - 08:00 AM
Garry
The only difference in those two numbers is the lift flag. One has a spring assist.
  • Sawdust said thank you
#10 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted August 19, 2016 - 08:46 AM
Garry
No, the serial number appears to be 87349.  I'll post some pics soon.
#11 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted August 19, 2016 - 09:04 AM
Ask and ye shall receive.  As you can see, the tag isn't in great shape.  Seller says it's tight and dry.  I have no reason to doubt this guy.
Tiller 1.JPG Tiller 2.JPG Tiller 3.JPG Tiller 4.JPG Tiller 5.JPG Tiller SN.JPG
#12 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,016 Thanks
  • 9,645 posts
Posted August 19, 2016 - 02:24 PM
That number doesn't match anything.
#13 GWest OFFLINE
GWest
  • 540 Thanks
  • 495 posts
Posted August 19, 2016 - 02:29 PM
Model number on the ID plate is 7-1211-7 and serial is 873419.  The dash 7 (-7) minus 5 = 2 = 1972. They added a 6th digit when model numbers ran for more than one year. This way they could identify the model year. You will see 6, 7, 8 and 9 on the tractors at the time also representing 1971, 1972, 1973 and 1974.
Garry
  • David Brown and LilysDad have said thanks
#14 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted August 20, 2016 - 09:43 AM
Garry
Thanks Garry.  As usual you are an absolute wealth of information when it comes to Wheelhorse.  I'm on the fence here because I have no time to go look at this thing.  I already told the guy to sell it if a buyer comes along.  I would hate for him to lose a sale waiting on me.  Having never owned a tiller for a tractor, I really have no clue as to what to look for.
#15 Racinbob OFFLINE
Racinbob
  • 76 Thanks
  • 68 posts
Posted August 23, 2016 - 12:09 PM
That does look like the tiller that Garry mentioned in post #6. Notice the rear idler pulley on the axle bracket instead of the tiller frame. That will work on a newer model. It has a 2 belt drive setup with pulleys mounted directly in front of the transmission. I didn't like that so I converted it to the later single belt drive. I utilized the older style axle bracket, did not use the transmission mount pulleys and used a later mid mount (under the motor) idler setup. I don't remember the belt length but it did take some experimenting. The slot hitch can remain on the tractor with that older tiller. A piece of bar stock in the slot hitch and a short chain connected to the tiller for the lift. When I was all done I liked it better than the newer style tillers. The only disadvantage was that the axle bracket wouldn't work with a snow blade. That didn't matter to me because the C-160 had a blower on it in the winter and I used a blade on a GT-1100. Obviously you can easily swap brackets if you need to.
