How to avoid mice in motor
10 replies to this topic
#1 tom tractor OFFLINE
tom tractor
  • 270 Thanks
  • 245 posts
Posted August 18, 2016 - 08:03 AM
The proverbial problem.... How do you avoid mice from nesting in the motor?
Dryer sheets, moth balls, etc...
What is the best method after the motor has been running and hot?
Suggestions?
  • Sawdust said thank you
#2 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted August 18, 2016 - 08:05 AM
I have a 5 foot black snake in the tractor barn and no mice to speak of.  You're welcome to it.
Edited by David Brown, August 18, 2016 - 08:05 AM.
  • rustyoldjunk, EricFromPa, KennyP and 5 others have said thanks
#3 Greasy6020 ONLINE
Greasy6020
  • 1,627 Thanks
  • 1,495 posts
Posted August 18, 2016 - 09:04 AM
I can hook you up with some barn cats, they are cheaper by the dozen!!
I'm in no way responsible for the odd 5 legged 3 eyed cat though, boss's cats are closely related, each generation is even closer...
Ok joke is over. I don't have a problem with mice, we seem to be at peace. Now those $&(/@@!! Squirrels, I have a war on them. I've found drawers in the work bench FULL OF PINECONES. Best thing for them is a pellet gun, after the "friend to all animals" lady goes to work.
I would try dryer sheets, probably can get them at the local dollar store, so if it does work, it's a cheap fix.
#4 case442 ONLINE
case442
  • 694 Thanks
  • 424 posts
Posted August 18, 2016 - 09:09 AM
Well I like the snake idea but! I have the same issue with mice and one of the things I do is leave the hoods up on my tractors. They seem to stay out when I do that I guess because they don't like the openness. Good luck with them
  • HDWildBill and Sawdust have said thanks
#5 tom tractor OFFLINE
tom tractor
  • 270 Thanks
  • 245 posts
Posted August 18, 2016 - 09:15 AM
I was thinking of connecting the tractor to my electric fence.
  • propane1 said thank you
#6 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted August 18, 2016 - 09:40 AM
Kill two birds with one stone.  Get rid of the mice and keep the battery charged!  Seriously the snake works far better than my cats.  He's just a little bit creepier.
  • MH81, Sawdust and propane1 have said thanks
#7 Sawdust OFFLINE
Sawdust
  • 6,154 Thanks
  • 3,548 posts
Posted August 18, 2016 - 09:49 AM
Even though I hate a snake I have seen two this year in my shop...no mice & empty traps. I recently also seen a small one so now I'm thinking I have a whole family...gives me the creeps. I heard placing a moat of moth balls around each tire helps also.
#8 boyscout862 ONLINE
  • 13,551 Thanks
  • 9,427 posts
Posted August 18, 2016 - 10:51 AM
I usually have a black snake but I haven't seen him this year. The mice seem more plentifull this year. Occassionally, I have a pair of hawks grabbing small critters but not enough. Good Luck, Rick
#9 chieffan ONLINE
  • 11,342 Thanks
  • 7,106 posts
Posted August 18, 2016 - 11:37 AM
I have used dryer sheet and leave the hoods up.  Just be sure you change the dryer sheets every few weeks. I check the oil before I start a tractor so that reminds me to remove the dryer sheets also.
#10 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted August 18, 2016 - 01:37 PM
I think the main two methods have been hit already... barn cats and barn snakes. Both work for me. I have no mice in my tractors... just paw prints on my hoods.
#11 propane1 ONLINE
propane1
  • 9,444 Thanks
  • 4,385 posts
Posted August 18, 2016 - 02:37 PM
Mice are a problem for sure. They filled the flywheel in my LGT 165 ford once, with the side panel insulation. Engine wouldn't even turn over, it was packed in so tight. Foxes help keep the mice away.
Noel
