Parts interchange?
32 replies to this topic
#16 GWest OFFLINE
GWest
  • 540 Thanks
  • 495 posts
Posted August 30, 2016 - 11:39 AM
The deck is marked Wheel Horse is several places, the one I am getting has the mounts like the one you posted, measured from blade tip to blade tip underneath was +/- 42", could a 42' not be mounted to my tractor?
Don't know if it will fit or not. Can't look it up because Wheel Horse considered a 42" deck too much for a 8hp engine so none in the attachment lists. Being a medium length frame I don't know if there is room for a long frame tractor mower.
Garry
  • adamjd200 said thank you
#17 adamjd200 OFFLINE
adamjd200
  • 2,023 Thanks
  • 2,152 posts
Posted August 30, 2016 - 11:42 AM
Garry
I'll try it I guess, worst case scenario, I can always get my $50 back fairly easy.
#18 adamjd200 OFFLINE
adamjd200
  • 2,023 Thanks
  • 2,152 posts
Posted August 31, 2016 - 10:39 PM
Think I may have an idea of what my current deck should fit.
Edited by adamjd200, August 31, 2016 - 10:42 PM.
#19 adamjd200 OFFLINE
adamjd200
  • 2,023 Thanks
  • 2,152 posts
Posted September 01, 2016 - 10:53 PM
Picked up the "new" deck earlier this evening, pics in morning.
#20 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,989 Thanks
  • 9,634 posts
Posted September 02, 2016 - 08:00 AM
1967 Model 1277
It would also fit a 1968-70 Charger/Raider/Bronco 12
Edited by LilysDad, September 02, 2016 - 08:01 AM.
#21 adamjd200 OFFLINE
adamjd200
  • 2,023 Thanks
  • 2,152 posts
Posted September 03, 2016 - 10:16 AM
Pics will come at some point, haven't had a chance to get any, haven't even unloaded it from  the truck.
#22 adamjd200 OFFLINE
adamjd200
  • 2,023 Thanks
  • 2,152 posts
Posted September 04, 2016 - 09:11 AM
Finally got pics.
  • LilysDad said thank you
#23 adamjd200 OFFLINE
adamjd200
  • 2,023 Thanks
  • 2,152 posts
Posted December 24, 2016 - 10:00 PM
May have found a 36" rear discharge deck, hard to tell for sure as they said they used it on a Raider12, any thoughts?
#24 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,989 Thanks
  • 9,634 posts
Posted December 25, 2016 - 08:32 AM
What info do you want? The 12 could handle a 42".
#25 adamjd200 OFFLINE
adamjd200
  • 2,023 Thanks
  • 2,152 posts
Posted December 25, 2016 - 10:09 AM
Just how different are the mounting points?
#26 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,989 Thanks
  • 9,634 posts
Posted December 25, 2016 - 01:41 PM
Any 1973 or newer Wheel Horse B or C series with the Attach-a-Matic mounting system will interchange implements. They have the same mounting hardware on the frame and the same mule drive on the front.
#27 adamjd200 OFFLINE
adamjd200
  • 2,023 Thanks
  • 2,152 posts
Posted December 25, 2016 - 05:35 PM
OK, so this one should work as it has that mule drive with it.
#28 adamjd200 OFFLINE
adamjd200
  • 2,023 Thanks
  • 2,152 posts
Posted December 29, 2016 - 12:31 AM
This is the deck in question.
Look what I just found on letgo! http://app.letgo.com/k8Mk/KU02gRCAuz - wheel horse deck 36 in rear discharge posted by pete gridley
#29 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,989 Thanks
  • 9,634 posts
Posted December 29, 2016 - 07:38 AM
That is the 1972 or older mounting system. Used on 1967-72 Raider,Charger, Broncos. It's hard for me to point out the differences when it is disassembled.
Edited by LilysDad, December 29, 2016 - 07:43 AM.
#30 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,989 Thanks
  • 9,634 posts
Posted December 29, 2016 - 07:50 AM
Finally got pics.
Notice in these pictures of the new style that the deck hangs from the two parallel bars. In the hardware photo in the Letgo ad is a large piece that looks wide and flat w/ a round bar that forms a cross. That piece replaces the bars in the old style.
PS - Part of the mule for the earlier Raider, etc. is permanently installed on the right side tractor frame; part is installed on the deck
Edited by LilysDad, December 29, 2016 - 07:54 AM.
