Clearing trails on gt
6 replies to this topic
#1 Greasy6020 ONLINE
Greasy6020
  • 740 Thanks
  • 718 posts
Posted August 17, 2016 - 09:31 AM
As a continuation of my thread on logging, I would need to clear trails to get into the bush...
As an idea, for clearing trails, I have seen this thing called a ratchet rake. I don't have anything that is mine that has a loader, so I am thinking about putting a ratchet rake on a a brinly rear blade... Anyone think this would work?
if I get desperate I can borrow dads skidsteer and grapple... It works good but, if rather use "my stuff"
  • chieffan said thank you
#2 David Brown OFFLINE
David Brown
  • 4,403 Thanks
  • 2,385 posts
Posted August 17, 2016 - 11:33 AM
I always just used a rear blade.  I would go over it until I had a decent path.  If I had some stubborn stuff, out came the Maddox to clear it away.  Most ground cover in the woods moves away fairly easy with a blade.
  • chieffan and Greasy6020 have said thanks
#3 chieffan ONLINE
  • 6,362 Thanks
  • 4,602 posts
Posted August 17, 2016 - 12:16 PM
Mow it first.  Bar mower if it is heavy or larger stuff.  Then a blade will finish it up.  If it is to big for the bar mower use a chain saw.  Need a pic to see what your dealing with.
  • Greasy6020 said thank you
#4 Greasy6020 ONLINE
Greasy6020
  • 740 Thanks
  • 718 posts
Posted August 17, 2016 - 01:36 PM
It's 3-5" poplar stumps, plus raspberry canes, grass and roots.
Can't take pic right now, have guy coming with new tractor...
#5 Rock farmer ONLINE
Rock farmer
  • 1,123 Thanks
  • 1,179 posts
Posted August 17, 2016 - 01:57 PM
Sounds like you need a flail mower.
Edited by Rock farmer, August 17, 2016 - 01:58 PM.
#6 BNK ONLINE
BNK
  • 1,005 Thanks
  • 449 posts
Posted August 17, 2016 - 07:36 PM
I did some work on our trails last year using the skid steer. Some saw work included. After pushing, cutting and hauling off the cut timber I smoothed out the trails with my little #40 box blade on the 149. I was real happy with the results with the equipment at hand.
#7 Greasy6020 ONLINE
Greasy6020
  • 740 Thanks
  • 718 posts
Posted August 17, 2016 - 10:20 PM
Sounds like I have some skid steer work cut out, along with rear blade work...
  • BNK said thank you
