jd attachments
10 replies to this topic
#1 pumpkintoter OFFLINE
pumpkintoter
  • 11 Thanks
  • 181 posts
Posted May 21, 2011 - 10:25 PM
ok im looking to put on another tractor in the fairly near future (got the wifes approval). right now i have my 316 with a kohler and with this i have a blade and a snow blower i know that the 140 and early 300 series will interchange with these attachments but is there anything else like 318 or 400 or 420 will work?
#2 Ron White OFFLINE
Ron White
  • 124 Thanks
  • 124 posts
Posted May 22, 2011 - 12:18 AM
Hello Pumpkintoter,
The front attachments you have will fit the 120, 140 and all 300 series tractors.
You didn't list any rear attachments but, if you do in fact have rear attachment for the 316K, these will only fit the closed frame models as the rear open frame models have there own series of rear attachments.
Good luck hunting for a new machine, it is always fun !!!!
  • pumpkintoter said thank you
#3 pumpkintoter OFFLINE
pumpkintoter
  • 11 Thanks
  • 181 posts
Posted May 22, 2011 - 12:20 AM
thanks for the reply i was really looking at maybe going to the 400 series but a nice 318 prob wouldnt be bad either..
#4 grnspot110 OFFLINE
grnspot110
  • 4,323 Thanks
  • 2,696 posts
Posted May 22, 2011 - 06:55 AM
The 400 is pretty much "attachment specific", 420 is 2" wider on the front! ~~ grnspot
  • pumpkintoter and SupplySergeant have said thanks
#5 pumpkintoter OFFLINE
pumpkintoter
  • 11 Thanks
  • 181 posts
Posted May 22, 2011 - 12:46 PM
well looks like im looking for a 318 that power steering would be nice.
#6 Ron White OFFLINE
Ron White
  • 124 Thanks
  • 124 posts
Posted May 22, 2011 - 03:25 PM
There are a couple more model options as well. The 322 with a gas powered 3cyl Yanmar engine and the 332 with a diesel version of the 3cyl Yanmar.
Both of which will have power steering , 2 spool hydraulics and dual brakes.
Here are my 140 and 332 that I have and both use the same front attachments, a 54 blade and 49 thrower.
  • 14,888 Thanks
  • 15,514 posts
Posted May 22, 2011 - 04:41 PM
I have seen an adapter on another site that will let you run 300 series attachments on the 420-430 series tractors. I will see if I can find it.
#8 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 22, 2011 - 04:53 PM
I think I saw an adapter that allowed you to install the quick hitch from the 425 ,445 and X700's on to the older tractors. There have been a number of versions of the QH. I have one that is narrow to fit the 2320 that I have. I plan to build an adapter to use the QH on my 314 as I already have the 54" blade and the hitch. It wouldn't be that hard to fab a hitch adapter to go between any of the series if you are only using the blade. It gets trickier if you need the PTO steady bearing for using the blower.
I think I saw the adapter at one of the WFM or MTF sponsor sites.
#9 MAV OFFLINE
MAV
  • 110 Thanks
  • 215 posts
Posted May 22, 2011 - 05:39 PM
ALZWELDING.COM might be what you guys are thinking about.
#10 grnspot110 OFFLINE
grnspot110
  • 4,323 Thanks
  • 2,696 posts
Posted May 22, 2011 - 06:58 PM
I've used the "frame squeezer" for one year (PO had sold the wrong blade w/a 318) on my 420. worked, but a bit of a nuisance! Longer hoses are needed, hard to connect hoses. After the first year, I found out what I needed for my blade; cut both ends off the mounting bracket, added 1" to each side, & welded it back together.
My (318) blade now fits my 420! ~~ grnspot
#11 pumpkintoter OFFLINE
pumpkintoter
  • 11 Thanks
  • 181 posts
Posted May 22, 2011 - 09:06 PM
id love to have a 332 i like those diesel fumes. but sadly that is prob out of my price range ive seen decent 420s going for around 2grand and that is at the higher end of my price range ill just keep my eyes open for now hopefully a deal of the century will pop up.. thanks for all your input fellas
