This tractor is leaking some oil on the right side of the engine, it is leaking around the long inspection plate, I thought I would pull the plate and seal it up. I pulled the oil filter canister and I pulled the hydraulic pump/distributor so I could get to the bolts. I went to remove the plate when I realized the bolts holding on the plate were finger tight. I tightened each bolt about 4 turns. I got it reassembled this evening and I will start it tomorrow to see if it's leaking.
Now I need to put some tape on a hydraulic pipe/hose on the rear lift cylinder and that should fix all of the leaks. Next I'm going to drive the tractor to town and pressure wash everything really good and then start painting. I already have all the sheet metal and lights pulled. After it's washed up and back home I am going to pull the wheels which I hate doing but I also hate it when people paint the rims red instead of silver.
