may have blown another coil
27 replies to this topic
#16 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 181 Thanks
  • 1009 posts
Posted May 24, 2011 - 05:43 PM
Product Detail
#17 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted May 25, 2011 - 05:03 AM
Product Detail
Thanks
#18 NUTNDUN OFFLINE
  • 10456 Thanks
  • 15622 posts
Posted May 25, 2011 - 05:30 AM
The Bosch blue coils do have a good following. A lot of the pullers use them.
#19 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted June 03, 2011 - 10:38 PM
on the foreign part topic, my genuine kohler high capacity fuel filter is made in INDIA WHAT A LOAD OF CRAP MAN.
#20 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted September 17, 2011 - 05:51 PM
Well, I blew another NAPA coil again :wallbanging:
I was cutting near the edge of the field behind the house with the 800 and all of the sudden the tractor stopped dead without any warning.
I walked back got some tools and found I wasnt getting spark. I checked all the connections and everything was fine so the only other thing it could be was the coil, Sure enough when I swapped out another coil it started right up!
I got about 3 months out of this coil
I'm beginning to wonder if a Bad batch of coils were sent out :confuse:
#21 grand ONLINE
grand
  • 2309 Thanks
  • 2074 posts
Posted September 17, 2011 - 06:16 PM
Sorry to hear that you are still having problems with coils. Sure hope that you get it straightened out Brian. When you have a continuing problem with the same part it can be quite frustrating.
#22 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted September 17, 2011 - 06:33 PM
call up and complain. and if that doesnt get you anywhere get into a good old screaming match with them. even if it doesnt get you a new coil. someone in a foreign country suffers over it.
#23 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5127 Thanks
  • 2912 posts
Posted September 18, 2011 - 08:04 AM
What # coil are you buying from NAPA, Brian?
If I'm not mistaken, they have a cheap coil and a more expensive coil, both of which have internal resistance.
Is your coil mounted where it is getting too much heat or vibration?
#24 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted September 18, 2011 - 08:17 AM
This is where the Coil gets mounted
I think The coil from NAPA cost around $24
The number on the coil is 1305
#25 olcowhand ONLINE
  • 44107 Thanks
  • 32302 posts
Posted September 18, 2011 - 09:17 AM
After all this coil trouble, I think I'd go the pricier route & get a high end racing type coil.
#26 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted September 18, 2011 - 09:21 AM
I think thats what I'm going to do
#27 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted September 18, 2011 - 10:04 AM
ACCEL 8140C - ACCEL SuperStock Ignition Coils - Overview - SummitRacing.com Requires external ballast resistor. C stands for chrome....only $1 or 2 higher than painted.
  • Bolens 1000 said thank you
#28 mikebramel ONLINE
mikebramel
    Ron Paul
  • 181 Thanks
  • 1009 posts
Posted September 18, 2011 - 10:38 PM
the blue bosch are epoxy filled
