may have blown another coil
27 replies to this topic
#1 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted May 21, 2011 - 08:46 PM
I was mowing with the 800 when all of a sudden it started revving out of control and the throttle wasn't working, so I pulled out the choke to slow it down a bit and turned it off.... Dummy me when I put on the carb I forgot to put on the retaining ring on the governor lever and it fell off into the lawn which is why I lost throttle control :wallbanging:
Luckily After about 30 minutes I found it intact in the lawn.
So then I put it back on , this time I put the retaining clip on LOL.
I went to pull start it and nothing.... Pull it again and still nothing. I take the plug out and no spark!
I look at all the connections and everything is fine. I then go to the points and clean them up a bit and take out some sitting oil in the bottom of the points box and go to pull start it again and still no spark!
At this point I'm thinking WTF could be wrong I just put a new coil in a few weeks ago. Finally after about 30 minutes of looking for the problem I decide to take the coil out and put in anther one... sure enough I was getting spark with the new coil.
I got the coil at NAPA and it says made in china.... I'ts only about 2 weeks old and I cant believe it went!
Anyone know what could have caused it to go?
I finished the lawn with the other coil with no problems at all.
#2 grand OFFLINE
grand
  • 2309 Thanks
  • 2074 posts
Posted May 21, 2011 - 09:00 PM
Sounds like the kind of luck that I have Brian. At least you figured out the problem and have a working tractor. Hopefully you will be able to get a replacement at NAPA without cost. I'm sure that nowadays it is next to impossible to find parts that are not made overseas. Let us know how you make out.
#3 NUTNDUN OFFLINE
  • 10457 Thanks
  • 15622 posts
Posted May 21, 2011 - 09:04 PM
I don't think anything really caused it to go. Just bum luck and coincidence. Glad you were able to find the piece for the governor in the grass. Hopefully you will have better luck with the next coil.
#4 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Yeah It seems like I've been having quite a few break downs this year........
#5 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted May 21, 2011 - 09:07 PM
I don't remember, was that an internal resistor coil? The other thing you may want to check is voltage output from your generator. It may be high and cooking your coil.
#6 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted May 21, 2011 - 09:11 PM
I'm not running a generator...... Its just a toggle switch as the on and off for power to the coil.
#7 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Yes it is a internal resistor
#8 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted May 21, 2011 - 09:14 PM
  • mikebramel said thank you
#9 bhts OFFLINE
bhts
    Bob's Lawn and Garden LLC
  • 1493 Thanks
  • 2181 posts
Posted May 21, 2011 - 09:27 PM
You are just not having any luck this year doc.
#10 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted May 22, 2011 - 04:41 AM
I sorry to hear that you are having bad luck Brian.
#11 JDBrian OFFLINE
  • 9682 Thanks
  • 14162 posts
Posted May 22, 2011 - 06:31 AM
If you get another one of the Napa coils check the resistance to make sure it is roughly the same as the original stock part. It could be that the coils are for use with an external resistor and there has been a mixup somewhere. If the resistance is OK then it could be your voltage is high or it spiked high when the governor disconnected. I'd check the voltage when it is running to make sure it's OK.
  • Bolens 1000 said thank you
#12 wvbuzzmaster OFFLINE
  • 4726 Thanks
  • 7423 posts
Posted May 23, 2011 - 12:22 AM
Don't get too upset in the coil Brian... I just fried the mag on the 88 Craftsman after the rewire. I sent 12 volts to the magneto which was actually not required to make it run... that wire... was for the ground to kill... And worse than that, I have to pull the engine to get the front half of the motor off to get the shroud off to get to the magneto... So I am looking at about half a day fix for a well thought through rewire project that had one little mistake in the drawing of the schematic... The magneto was the one electrical component that I did NOT want to replace in the rewire project. But I am glad I saw this thread cause I will NOT put anything less than USA brand in that tough to get to location!
#13 jupiter OFFLINE
jupiter
  • 1 Thanks
  • 39 posts
Posted May 24, 2011 - 03:30 AM
Was it a returned one? Thats how I got stuck with a new regulator that over-charged, blowing my 20amp fuse. I didn't give it any second thoughts that the box was opened up. Aftering opening the case up, I could see some tell-tale marks that someone before me tried to adjust it. Having bought it new for 75 dollars I had to make it work as I was stuck with it. Took me many hours to get a non-adjustable regulator back in spec.
#14 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted May 24, 2011 - 08:03 AM
no, it was new... the package was still sealed.
Guess I'm going to get an OEM one this time
#15 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted May 24, 2011 - 04:56 PM
I've heard of many OEM Kohler coils doing the same thing when almost new. Just bad luck & bad craftsmanship on the manufacturer's part.
