Pressure washer pump Question
10 replies to this topic
#1 secondtry OFFLINE
secondtry
  • 1,890 Thanks
  • 1,384 posts
Posted August 15, 2016 - 11:09 PM
   Today I bought a Troy built pressure washer. Rod through the block. 7.5 hp briggs ohv vertical. I have setting around a 6.5 hp Horizontal Honda clone. Will the pump care if it is vertical or horizontal?    Don
  • MFDAC, Sawdust and chieffan have said thanks
#2 lyall OFFLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted August 15, 2016 - 11:12 PM
rotation is the biggest problem
  • secondtry said thank you
#3 secondtry OFFLINE
secondtry
  • 1,890 Thanks
  • 1,384 posts
Posted August 16, 2016 - 01:01 AM
The rotation is counter clockwise looking at the output shaft on each engine. I haven't checked shaft size yet what I am most concerned with is lubrication flow.    Don
  • MFDAC said thank you
#4 chieffan OFFLINE
  • 10,133 Thanks
  • 6,632 posts
Posted August 16, 2016 - 06:31 AM
Shouldn't make any difference as long as you keep water to it.
#5 dodge trucker ONLINE
dodge trucker
  • 2,432 Thanks
  • 3,122 posts
Posted August 16, 2016 - 12:09 PM
I thought that all small gas engines rotated the same way.
As far as finding a power washer with a good pump and bad motor that is unusual
Craigslist is loaded with power washers with bad pumps.
#6 Sawdust ONLINE
Sawdust
  • 5,656 Thanks
  • 3,370 posts
Posted August 16, 2016 - 05:58 PM
Sounds like he had a bad engine when he bought it so the pump could still be bad if he hasn't tried it yet. Your right I've seen plenty with bad pumps but good engines.
#7 Sawdust ONLINE
Sawdust
  • 5,656 Thanks
  • 3,370 posts
Posted August 16, 2016 - 05:59 PM
Do you know if the pump is good.
#8 shorty ONLINE
shorty
  • 5,481 Thanks
  • 5,261 posts
Posted August 16, 2016 - 07:48 PM
The ones that I have used were oil lubed pumps. It could mess with that.
#9 MFDAC OFFLINE
MFDAC
  • 3,215 Thanks
  • 1,586 posts
Posted August 16, 2016 - 07:52 PM
I recently had to put a new pump on my Craftsman as it must have frozen last winter. I didn't do a very good job draining it last fall. Decent priced Craftsman ones were about impossible to find but discovered Troy Bilt uses the same Annovi pump and they were more affordable.
As Chieffan stated as long as it has water there is lubrication so angle shouldn't matter. Here is where mine cracked so you can see where to look for freeze damage and the Annovi tag on the Craftsman washer.
DAC
Edited by MFDAC, August 16, 2016 - 07:53 PM.
  • Sawdust said thank you
#10 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,458 Thanks
  • 5,765 posts
Posted August 22, 2016 - 05:40 AM
The easiest way to find out if it's cracked is put a hose on it!
#11 secondtry OFFLINE
secondtry
  • 1,890 Thanks
  • 1,384 posts
Posted August 24, 2016 - 11:04 PM
     Update. I dismantled the pressure washer. Became instantly obvious that mounting the pump to the horizontal engine would be extremely challenging. So my focus changed to finding an appropriate engine. Back to Craigslist. Found a mower with a 6.5 30$. Guy says  runs good blade hub is broken. I was kind of hesitant because it was a 60 mile round trip. After a few emails I decide its worth a try. When I get there I find that in an attempt to attach a blade he has welded the blade to the crank. Says "that didn't work". Engine starts right up, runs great, no smoke. I buy it and go home.
     Crank shaft on the both engines are the same diameter, same key way. Mower shaft is 1 3/8" longer. I can only remove 5/8" while saving the key way. I found a piece of 7/8 plate in my iron pile & cut spacers for between the pump and the engine cut 5/8 of the crank, Bolted it all back together. It works great now, If I calculate value added and time spent I can pay my self 1.38 an hr. Good thing I am retired.  Don.
  • Alc, KennyP and Cvans have said thanks
