Busy With The New Welder
6 replies to this topic
#1 Guest_hooligan_*
Guest_hooligan_*
  • Guests
Posted March 23, 2010 - 10:54 PM
Got a new Hobart 125 EZ gasless wire welder for 150.00, used once on a project, with 2 full spools of wire. I have a real nice cart to put it on after a little fab work. I also cut off the old broken jack on the trailer and welded a new one on. Tomorrow I pick up a HUGE welder with a 12 hp Tecumseh engine on it, 40 gal+ tank 2cast iron air cylinder, well over 400 lbs, for FREE. Motor needs a carb, no problem. i got teh rest of the prep work done on the JD214 deck clean and rearranged all the tractors to fit in the barn, shop garage. I did all this after 3pm, had to work for a couple of hours, cause it's a Toosday.
#2 mjodrey OFFLINE
Posted March 24, 2010 - 04:48 AM
Congrats on your new welder,if you didn't have one before,you'll wonder how you survived without one.
#3 Bolens 1000 OFFLINE
  • 14,919 Thanks
  • 18,111 posts
Posted March 24, 2010 - 05:46 AM
Congrats on the new welder.:bounce:
#4 Bill56 ONLINE
  • 839 Thanks
  • 2,179 posts
Posted March 24, 2010 - 05:59 AM
Sounds like you got a couple of really good deals!
#5 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted March 24, 2010 - 06:37 AM
Congrats on the new welder, sounds like you got a heck of a deal on the other one too, can't beat free.
#6 Guest_hooligan_*
Guest_hooligan_*
  • Guests
Posted March 24, 2010 - 03:32 PM
The second "welder" wasn't a welder, but a air compressor. H160 or H180 engine with overhead valves, 2 stage cast iron bink compressor, it took four big guys to load it in the van. I think any 10 hp or larger Tecumseh carberator will fit. Oh yeah wired to the motor was a tag and receipt of a complete engine rebuild on the Tecumseh, seems as the PO stole the carb for a cement mixer right after the rebuild.
#7 olcowhand OFFLINE
  • 40,373 Thanks
  • 31,177 posts
Posted March 24, 2010 - 07:00 PM
Can't beat the deals you get Mike!!
