broke my johndeere 155c 25hp. need help.
john deere 155c 25 hp
8 replies to this topic
#1 tammy OFFLINE
tammy
  • 1 posts
Posted August 15, 2016 - 08:05 AM
oil plug came loose and I mowed with no oil. put new in . runs bad. when I engage mower , power goes to nothing. did I ruin it ? what should I do ? just spent 175 bucks rebuilding the deck with new pulley's and belt.
#2 MiCarl ONLINE
MiCarl
  • 1,910 Thanks
  • 1,019 posts
Posted August 15, 2016 - 08:29 AM
I'm going to assume you ran it until it seized up then got it broke free after it cooled down?  Quite likely you chewed up the piston/rings/cylinder.
Dry/Wet compression check should give you an idea if my guess is correct.
#3 boyscout862 OFFLINE
  • 12,517 Thanks
  • 9,027 posts
Posted August 15, 2016 - 11:01 AM
Welcome to GTT. I agree with above. Unfortunately to cost of rebuilding/replacing the engine may not be worth it. Doesn't that have an automatic low oil shutdown? Good Luck, Rick
#4 chieffan OFFLINE
  • 9,517 Thanks
  • 6,392 posts
Posted August 15, 2016 - 11:18 AM
Find a decent used engine and do a swap.
  • stiemmy said thank you
#5 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted August 15, 2016 - 01:12 PM
X2
#6 DZG OFFLINE
DZG
  • 607 Thanks
  • 525 posts
Posted August 21, 2016 - 01:07 PM
If your lucky you may have just chewed the camshaft
#7 MH81 OFFLINE
Posted August 22, 2016 - 05:46 AM
I will echo the used engine. You will need time to fix this engine right and a used engine will provide that for you.
Make sure it's a good one. Then you can tear yours down and do a rebuild on it if it's worth it.
Then you can put it back on the machine and resell the used engine.
#8 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted August 22, 2016 - 10:06 AM
I would assume on a newer machine there would be a low oil shutoff. Otherwise I agree with above statements
#9 Evin OFFLINE
Evin
  • 1 posts
Posted July 23, 2017 - 06:19 PM
I grew up with tractors. I remember sitting on my Dad or Granddads lap steering the tractor. When I got older I  could set the throttle or move the shift lever from one gear to the next. Somebody once asked me "Who taught you to drive?" " Nobody" I told them, "I already knew how to drive by the time my feet could reach the pedals."
        Great Forum! I just downloaded a Service Manual that covers my Bolens 1050. Saved me the embarrassment of asking some really stupid questions. Thank You.
