Added a Farm King
4 replies to this topic
#1 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,605 Thanks
  • 1,306 posts
Posted August 14, 2016 - 12:19 PM
I have had several 990's and really liked them but its been a while so it was time for another one. After a good carb cleaning and adjusting the points it runs great. I also put one front tire on it. The hydro is sluggish though so I changed filters which didn't help but when the fluid came out I had a pretty good idea that it might not. Lots of metal shavings including some big ones. Looks like some hydro work is in order. It has type F fluid in it,someone suggested flushing and going to a thicker fluid like a 10 30 or 15 40 might help until I get to fixing it right. I don't know if that would help or not.
  • sacsr, CRFarnsworth, boyscout862 and 4 others have said thanks
#2 Merle013 ONLINE
Merle013
    If I can't do it slow then it's not going to get done.
  • 264 Thanks
  • 181 posts
Posted August 14, 2016 - 01:49 PM
Nice Tractor! I have worked on skid steers and larger tractors hydraulics and when I have found metal shavings it was time to rebuild or replace parts. Even if you flush the system and get every little piece of metal out, then you still have a worn or broken part just waiting to fly apart and destroy everything. Are you going for full restore or are you keeping the petina?
  • rustyoldjunk and boyscout862 have said thanks
#3 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,605 Thanks
  • 1,306 posts
Posted August 14, 2016 - 02:35 PM
Its a good straight and solid original Merle and those are my favorites,so most likely it will stay original.
#4 Merle013 ONLINE
Merle013
  • 264 Thanks
  • 181 posts
Posted August 14, 2016 - 03:46 PM
Glad to here it. Someone the other day on here mentioned "Owatrol". It is supposed to stop the rust and preserve the patina. I have not tried it myself but I do have a Continental that I want to try it on.
  • rustyoldjunk said thank you
#5 Merle013 ONLINE
Merle013
  • 264 Thanks
  • 181 posts
Posted August 14, 2016 - 03:49 PM
Bolens800UK was the one who mentioned it.
