Back to the UT620.
9 replies to this topic
#1 glgrumpy OFFLINE
  • 8,610 Thanks
  • 7,920 posts
Posted August 13, 2016 - 11:56 PM
Been sitting in garage since spring when first got into it. Was having trouble running the hydro lines in right places. There's a lot of them! Think I have figured it out now. I was putting back in the coolers, one on each side and using two big wrenches to put in the fittings there, kinked one of the aluminum tube ends for fitting. Darn!  I have parts extras, so used one of those, went OK this time. I was slipping the plastic dash on and off this thing to check fit and length of hoses going up to holes in dash area for shut-off valves and such. Went to lift it off one time and whole side broke off the darn thing!  It was already broken up where the hydro valves mount, and around edges where it mounted to any part on frame/body. Was planning on little fiberglas work to fix later, but now, not sure what is gonna happen. I'm going to make the hood and front metal, might as well make the dash too. I hate fabricating things from scratch! That darn plastic they used in 90's is NO Good!  Once it gets some age on it, gets real brittle and sometimes just looking at it is too hard on it and it breaks!! I have more of these tractors, and all have broken plastic hoods and sides/dashes.  New parts not avail and surely any old ones if found would be no better anyway. I'll have to make up some temp mount spots for things on this, just to hold them up and be able to keep going on the assembly of it.  I really hate working on this new stuff with no room, packed up tight, no access and then that body being junk.  Too many systems on them to be messing with. All nice when you buy it new, but with little maintainance on one like this, can be a disaster to work on later.
  • MNGB said thank you
#2 MNGB ONLINE
MNGB
  • 2,132 Thanks
  • 1,413 posts
Posted August 14, 2016 - 07:40 AM
Hi gl, good to hear your working on the UT, sorry to hear about the misfortune with the dash, is that ABS plastic that UV rays get to over time? I hear you about starting from scratch would have been easier to repair the crack but then again it might have broke in another spot.
#3 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted August 14, 2016 - 09:27 AM
This one?
#4 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted August 14, 2016 - 09:42 AM
If that's the one, not sure why you would be running into unexpected problems. Looks to be a one owner well cared for only driven to church on Sundays model.
#5 glgrumpy OFFLINE
  • 8,610 Thanks
  • 7,920 posts
Posted August 14, 2016 - 10:28 AM
STOP IT!  CAT!  Not in the mood for crap this week. :(  Hitting bottom on the depression scale again and ready to give it ALL to someone else and be done. This is all part of my twice a year mood swing.  Too much to do, not enough time and money, working too long of hours at the plant.  Need a vacation, which I Never Take to relax and get away.  There.....that out of way, YES, that is the junker. Just needs a good Hug and Kiss and will be all right! :smilewink: :big_hug:
#6 SNUFFY OFFLINE
SNUFFY
  • 187 Thanks
  • 268 posts
Posted August 14, 2016 - 10:39 AM
Hang in there Grump.....good lookin` bones on that thing though.
#7 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted August 14, 2016 - 01:28 PM
When you say "twice a year mood swing",you mean that twice a year you are in a good mood?
#8 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted August 14, 2016 - 01:44 PM
Okay, but be warned: I don't have any openings until mid-October, so crap-giving will be sporadic at best until then.
#9 EconChuck OFFLINE
EconChuck
  • 252 Thanks
  • 289 posts
Posted August 15, 2016 - 09:02 AM
Grumpy, you obviously should have built a bigger shop annex than the one you did this year!!
Chuck
#10 glgrumpy OFFLINE
  • 8,610 Thanks
  • 7,920 posts
Posted August 15, 2016 - 06:24 PM
Yep! Would have been nice, but too much $$$ AND, don't forget I'm getting out of this hobbie soon, so not time to invest in more storage for that now is it?  I already have it sort of jambed full on floor space, now working on shelves and hanging stuff on walls and in attics to see just HOW MUCH it can really hold!
