3 point mower deck
30 replies to this topic
#16 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted August 19, 2016 - 03:36 PM
When I bought my Ariens, it was missing the rear pto. The owner said he pulled it off to put on his 318. How easily it fit, I don't know. Kind of what I imagined you are working towards.
That is what I am thinking, just looking at the back of it they both look the same.
If I could figure out one then I should be able to do the same to the other.
#17 shorty ONLINE
shorty
  • 5,834 Thanks
  • 5,417 posts
Posted August 20, 2016 - 10:52 AM
Over in the Ariens forum, there is a picture of a Ariens clutched rear pto in a New Holland. On that one he used a different connection to complete it. I need to find it and check it again.
#18 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted August 20, 2016 - 05:13 PM
Robert, just do like I do and use the normal female quick attach PTO shaft.  I bought a piece of 15 spline shafting, then ground a groove in it so it will lock into the PTO on the tractor.  Then grind another groove for the pto part to lock into.
  • limebuzz, shorty and michael.kitko have said thanks
#19 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted August 21, 2016 - 02:35 PM
Do you happen to have a picture of that??
#20 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted August 21, 2016 - 06:08 PM
I went & pulled it out for a pic.  It only needs 2 grooves, but I made the first groove to go into the tractor's pto too far in, which left too much shaft sticking out and didn't give room for my tiller pto shaft.  So I cut the center groove to shorten it.  The left end goes into the tractor.   Works perfectly.
  • Alc, KennyP and CRFarnsworth have said thanks
#21 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted August 21, 2016 - 08:22 PM
Pretty darn neat!!
#22 Robert Webb OFFLINE
Robert Webb
  • 930 Thanks
  • 436 posts
Posted August 22, 2016 - 07:47 AM
Daniel,  That is kind of what I was looking for. It is going to be a little while before I can do anything with this project due to having knee surgery back in July. I am still on "limited weight" restriction and have to use crutches to get around.  But at least I have a starting plan.  I looked at the deck the other day and I think I have an idea of how to attach the uprights and braces, will just be a matter of working it all out.
#23 Robert Webb OFFLINE
Robert Webb
  • 930 Thanks
  • 436 posts
Posted August 23, 2016 - 07:19 PM
Daniel, what do you think about using the front PTO shaft (actually the MID PTO shaft)   the one that you hook the mower drive shaft to?  Unless I have thrown it away, I have at least one of those shafts in the garage somewhere.....lol
EDIT......nevermind, that shaft wont work without a lot of work.  The grooves are too close to the end of the shaft.
Edited by Robert Webb, August 23, 2016 - 07:22 PM.
#24 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted August 23, 2016 - 07:26 PM
My shaft actually was a front PTO shaft out of a Simplicity Sunstar.  I used a 4 1/2" angle grinder to make my grooves
#25 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted August 23, 2016 - 10:03 PM
Here are several choices for the 1X15T shafting.
http://www.surplusce...:1\"\-15\ Tooth
  • ducky said thank you
#26 shorty ONLINE
shorty
  • 5,834 Thanks
  • 5,417 posts
Posted August 24, 2016 - 04:39 AM
Dan's setup looks very simple n easy compared to what I could think of.
#27 Robert Webb OFFLINE
Robert Webb
  • 930 Thanks
  • 436 posts
Posted August 24, 2016 - 11:06 AM
Daniel, I looked at the JD shaft last night and it is only splined about an inch on either end and smooth in the middle.  I would be concerned about the shaft not going far enough up into the PTO gearbox so I will probably just order one that is completely splined and then I can cut the groove for the collar lock where I need it.
Thanks guys.
I am going back to work Monday on "OFFICE DUTY ONLY" per my surgeon (I am still having to use a crutch to put "partial weight" on my right knee) and wont be able to work on this project for at least a month or so (well I am not SUPPOSED to be anyway)  I have a couple of projects that I would like to get started on so I may spend some time cleaning out the barn at Dana's house to give me a place to work and then when I feel like it, I can pull up a stool and tinker.......lol
  • olcowhand, KennyP and michael.kitko have said thanks
#28 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted August 25, 2016 - 02:56 PM
Does someone make or offer the female counter part to the 1"x15spline??
#29 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted September 05, 2016 - 11:38 AM
Here are 2 for example
http://www.paulbpart...before-shipping
http://www.surplusce...1615-1-1561.axd
#30 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted September 05, 2016 - 02:29 PM
On that second one, it says it is weldable, I guess a person could get a double ended male that has splines on both ends and weld that piece on the end of the shaft right??
