126 clutch not disengaging
6 replies to this topic
#1 apc237 OFFLINE
apc237
  • 7 Thanks
  • 15 posts
Posted August 12, 2016 - 06:42 PM
Well I have a 126 that has been driving me nuts, clutch won't disengage no mater what I do,replaced springs,greased pilot shaft,adjusted pedal in and out. Anybody have ideals
#2 KennyP ONLINE
  • 38,354 Thanks
  • 45,921 posts
Posted August 12, 2016 - 07:04 PM
Sounds like the disk is stuck together.
#3 olds45512 OFFLINE
olds45512
  • 1,339 Thanks
  • 677 posts
Posted August 12, 2016 - 07:26 PM
Sounds like the driveshaft has grooves in it that prevent the throwout bearing from sliding.
#4 EricFromPa ONLINE
EricFromPa
  • 3,658 Thanks
  • 3,114 posts
Posted August 12, 2016 - 09:27 PM
They can do both.The laminated clutches are usually the ones that seize or rust fast to the disks.
Parts Manual is here if you don't have it.Page 15 is the clutch assembly.Make sure you are not missing any parts.Namely the adjustable rod that pulls the clutch
http://gardentractor...6-parts-manual/
Clutch and brake adjustment is on pages 55-62 on This manual.
http://gardentractor...service-manual/
Did you have the Driveshaft out of the tractor? You said you replaced springs? Clutch spring and teaser spring?
It could be brake adjustment related.1st 3/4 of the pedal is all clutch so adjust it so the brakes don't come on till the clutch disengages fully.
You can unhook the brakes until you get the clutch working.Just pull the cotter pins on the calipers and let the rods hang loose.
Verify that Parts # 9 and 10 are not wore out.Clutch hanger and Clutch release leaver.The 4 holes where the long bolt connects the 2 gets really worn on these and makes the clutch not work.They are easily repairable.
Post a couple Pictures of the underside of your tractor from the clutch disk back to the last roll pin.If something is out of place we'll find it.
Edited by EricFromPa, August 12, 2016 - 09:40 PM.
#5 apc237 OFFLINE
apc237
  • 7 Thanks
  • 15 posts
Posted August 13, 2016 - 06:52 AM
Thanks guys will get pics and post
#6 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted August 13, 2016 - 10:07 AM
:camera:
#7 apc237 OFFLINE
apc237
  • 7 Thanks
  • 15 posts
Posted August 13, 2016 - 03:27 PM
Here are some pics, they are the best I could get for now
