Cub Cadet 127 head scratcher
cub cadet starter generator
12 replies to this topic
#1 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted August 12, 2016 - 08:01 AM
Hopefully you guys can help me, I recently rebuilt my 127, new starter, wire harness, solenoid, points, electronic ignition, coil, well pretty much everything minus the voltage regulator. Finally started it up last night and ran great, was charging and everything looked good. I started to mow with it for about fifteen minutes and noticed my amp gauge showed no charge so I look and my new starter is smoking out of the case vent. I thought possibly just oil from shipping but after an hour of cooling down I now have a no start situation, checked the battery fully charged. Could the voltage regulator have caused this? What do you all think this could be? Thanks in advance.
#2 boyscout862 OFFLINE
  • 13,431 Thanks
  • 9,380 posts
Posted August 12, 2016 - 08:18 AM
I'm puzzled too. There are several possibilities. Somewhere in our Manuals Section is a good pamphlet on how to diagnose these problems. I would start by inspecting the starter to see if it fried. Good Luck, Rick
  • Eric said thank you
#3 Billy M ONLINE
Billy M
  • 710 Thanks
  • 561 posts
Posted August 12, 2016 - 08:24 AM
It's possible the regulator shorted the field to run at full charge capacity and burn it up.  Did your battery puke any electrolyte out?  Your battery would have been boiling pretty good if it ran long enough with the regulator/genny in that condition.
#4 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted August 12, 2016 - 08:29 AM
Battery seems fine but it is full size car battery and was brand new. I plan on troubleshooting this but to that matter this is how I have arrived here. This whole evolution started due to a slow starter generator, it was worn beyond repair, I suspect the previous owner was not much for maintaining anything.
  • chieffan said thank you
#5 Bolens 1000 ONLINE
  • 15,282 Thanks
  • 18,232 posts
Posted August 12, 2016 - 08:40 AM
Have you tested to see what output the regulator was charging the battery at? These delco remy starters will overheat and prematurely wear out if the regulators are set at anything higher than around 14 volts
My starter shop said regulators should be set to run at 13-14 volts
  • Alc, Eric and chieffan have said thanks
#6 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted August 12, 2016 - 09:14 AM
It was charging slightly above thirteen volts and then it looked like it was no longer charging and smoke started to come. Can't start the tractor now so kind of have to figure out how to proceed a bit blind. Worst part is the voltage regulator and starter are expensive parts to be replacing without finding the exact problem first, I would hate to burn up another starter.
#7 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,940 Thanks
  • 2,459 posts
Posted August 12, 2016 - 09:47 AM
Probably more than you want to know:  http://gardentractor...lletin-img-150/  and
http://gardentractor...rvice-bulletin/
Check if the starter/generator is grounded well to its mounting, and ground is good back to the battery.
Take the belt off the starter, and use jumper cables to ground the starter and apply 12v to the "A" terminal of the starter.  ...The starter should run.
If not, more than likely one or both field coils are possibly fried.
#8 48willys OFFLINE
48willys
  • 171 Thanks
  • 86 posts
Posted August 12, 2016 - 09:53 AM
Make sure your start circuit isn't stuck on, if something shorted out and at was trying to run the generator it may fry it. Also make sure the wire from the starter solenoid isn't grounding on anything and causing a short. Only a guess but I would say if it had something to do with the regulator it would have heated up the wiring to it too.
#9 olds45512 OFFLINE
olds45512
  • 1,341 Thanks
  • 677 posts
Posted August 12, 2016 - 11:01 AM
Smoke and electronics don't mix so it's probably junk, when you say the starter/generator is new do you mean one of the Chinese ones off eBay?
Edited by olds45512, August 12, 2016 - 11:42 AM.
#10 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted August 12, 2016 - 08:40 PM
Little update, I tried jumping the starter and it's a no go took the belt off and she doesn't even think about turning. Yes it was a epay unit, I suspect it was built poorly as it was a bit stiff to turn and not as smooth as my original. I am going to order a new starter generator, ameter, voltage regulator, and some other bits tonight. This time I will be ordering from ccspecialties they should be reputable.
#11 olds45512 OFFLINE
olds45512
  • 1,341 Thanks
  • 677 posts
Posted August 13, 2016 - 02:20 PM
no, do not order another new starter/generator, the new ones are junk. What's wrong with the original one and why don't you have it rebuilt?
#12 chieffan OFFLINE
  • 10,885 Thanks
  • 6,916 posts
Posted August 13, 2016 - 08:31 PM
:iagree:   Any electric motor repair shop can rebuild that starter/generator.  I have an old IH repair shop that has done a few of mine and have had good luck with them.  If you have to replace it, get an old original unit and even if you have to have new bushings/bearings put in you will have a much better unit.
#13 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted August 14, 2016 - 12:46 AM
I do not live near, well anything and also the original starter was not on this tractor when I bought it. So currently I am sitting on two new but burnt starter generators. I appreciate all things old also and will rebuild what I can as nothing seems to be of the quality it used to.
Also tagged with one or more of these keywords: cub cadet, starter generator
