JD 316
3 replies to this topic
#1 tom tractor OFFLINE
tom tractor
  • 236 Thanks
  • 225 posts
Posted August 12, 2016 - 04:55 AM
My 316 is very jumpy (hydro) when moving from a stop. The fluid in the hydro sight glass shows that it is over filled. Could that be causing the jumpy behavior? Or any other suggestions. The tractor is in excellent shape and has 900 hours.
#2 JD318420 OFFLINE
JD318420
  • 65 Thanks
  • 97 posts
Posted August 12, 2016 - 06:41 AM
Check linkages for wear, check damper cylinder, adjust according to manual.
#3 Trav1s ONLINE
Trav1s
  • 3,308 Thanks
  • 4,363 posts
Posted August 12, 2016 - 07:30 AM
Got a serial number?  Adjustments and repairs are determined by the production range of the machine.  There are also two different versions of the 316 which add confusion to the conversation.
#4 tom tractor OFFLINE
tom tractor
  • 236 Thanks
  • 225 posts
Posted August 12, 2016 - 07:34 AM
The tractor is a 1989. The tractor is very touchy while switching from reverse to forward. it jumps forward rather thank slowly engaging? The hydro is very quiet and extreamly responsive and strong. It is just extreamly sensitive. Thoughts on how to make it less touchy?
Edited by tom tractor, August 12, 2016 - 07:44 PM.
  • Trav1s said thank you
