Johnson Loader - Need Hydraulic Help on MF16 attachment
loader mf16 johnson hydraulics pump
2 replies to this topic
#1 jah457 OFFLINE
jah457
  • 8 Thanks
  • 23 posts
Posted August 12, 2016 - 04:40 AM
Good morning all,
I have a 1975 MF16 and just bought a Johnson Work Horse Midget 10 Loader without any pump. I am not familiar with hydraulics and need to configure a hydraulic pump whether PTO, inline shaft, or electric. Could I tap into the mower deck hydraulic lift lines? If anyone could provide some guidance that would be greatly appreciated.
The hydraulic pumps I have looked at can't take side load to be run from a belt off the front PTO, so I need to either remove the PTO and attach to the crankshaft using a love joint assembly but I don't know the size of the crankshaft end, or whether it's keyed or tapered.
As you can see, I'm lost in this area and would appreciate any help.
Thx, John
  • Traill95 said thank you
#2 boyscout862 OFFLINE
  • 12,859 Thanks
  • 9,173 posts
Posted August 12, 2016 - 06:06 AM
Congratulations on finding an Front End Loader(FEL). It will be easiest if you find a pump that can take side ways loading so that you can mount it to the side of the engine. Do not try to use the tractors' hydraulics as it won't have the reservoir capacity. Check our Manuals Section for Johnson Workhorse FEL manuals and do-it-yourself plans. The manuals may be under several different brands. Keep us posted on your progress. Good Luck, Rick
There is a manual for the model 14 in the MF section http://gardentractor...ruction-manual/
Here is a model 10 in the Bolens section http://gardentractor...s-800-900-1000/
Here is a model 10 in the Cub Cadet section http://gardentractor...install-manual/
Edited by boyscout862, August 12, 2016 - 08:11 AM.
  • DougT said thank you
#3 jah457 OFFLINE
jah457
  • 8 Thanks
  • 23 posts
Posted August 12, 2016 - 03:55 PM
Thx so much Rick.
Also tagged with one or more of these keywords: loader, mf16, johnson, hydraulics, pump
