what's the difference between a hydro filter and a oil filter ?
5 replies to this topic
#1 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,625 Thanks
  • 1,311 posts
Posted August 10, 2016 - 08:36 PM
I remember a discussion a long while back somewhere about the differences and why not to use at least certain oil filters on your hydro tractor but I don't remember the specifics.
 Any gurus here that can fill me in ?
#2 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 10,437 Thanks
  • 5,757 posts
Posted August 10, 2016 - 08:52 PM
I'm no guru but I believe there is a check valve on one of them..
  • rustyoldjunk said thank you
#3 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted August 10, 2016 - 09:26 PM
Check/Bypass valves and micron size.
Hydraulic systems want filters in the 10-20 micron range. some systems use both
I am unsure what the micron requirements are for Engine oil filter, but I do know a lot of them have a bypass built in to keep oil flowing when the filter plugs up.
I have no idea if the hydraulic filter have the bypass.
#4 Alc OFFLINE
  • 6,883 Thanks
  • 7,459 posts
Posted August 11, 2016 - 05:37 AM
If your friends to a NAPA store salesperson you should ask of an old " Filter Interchange & Product Numeric Catalog "  when they get their new ones. There's a wealth of info in them as far as filter sizes , micron , check valve , gasket size ect.    It will have air , fuel oil ,plus  other info along with pictures .
#5 old coot OFFLINE
old coot
  • 122 Thanks
  • 88 posts
Posted August 12, 2016 - 06:06 AM
i never gave that much thought , always used whatever napa gave me as far as filters for the oil or hydro , but they must be right at napa , never had any trouble in all these years
#6 Cat385B ONLINE
    HAZMAT CAT
  • 13,966 Thanks
  • 9,997 posts
Posted August 12, 2016 - 04:50 PM
Usually $20, at least.
