Onan CCK A pull start mechanism
6 replies to this topic
#1 frgccss OFFLINE
frgccss
  • 1 Thanks
  • 3 posts
Posted May 20, 2011 - 07:32 PM
Have a really old (stamping on block says 1962) Miller engine welder with an Onan CCK A engine. The engine has a pull start of the most basic type, wrap the cord around the sheave and pull! Anyone know where I might find a pull starter that automatically rewinds?
#2 MH81 OFFLINE
Posted May 20, 2011 - 09:39 PM
It might be easier to find a belt driven starter and pulley for it. Check the hole pattern where the pulley would bolt up to the flywheel... May be the same as the old Briggs or Techumseh's
#3 frgccss OFFLINE
frgccss
  • 1 Thanks
  • 3 posts
Posted May 21, 2011 - 06:50 AM
Thanks, I'll look into that. Won't do me any good in the field but where there's power it would make things easier.
#4 caseguy OFFLINE
  • 1,628 Thanks
Posted May 21, 2011 - 07:25 AM
It would if you also installed a battery, a solenoid, and a start switch. Our Lincoln "Rangers" at work are all electric start.
#5 dryrun OFFLINE
dryrun
  • 56 Thanks
  • 342 posts
Posted May 21, 2011 - 08:02 PM
frg, If you are going to keep the engine on the welder, check for wiring diagrams. If my old grey matter is not too jelled up, a lot of these welders, Lincoln in particular used windings in the generator to be used as a starter. Might check wiring diagrams, and see if on control panel, there is a heavy duty push button that is used as a start switch. Just sayin.
regards, George.
Also check salvage yards, etc for generator onans, had real good hvy duty pull starts. Boomer will probably be of more help.
Edited by dryrun, May 21, 2011 - 08:06 PM.
forgetfulness.
#6 chjr69 OFFLINE
chjr69
  • 5 Thanks
  • 13 posts
Posted May 21, 2011 - 11:51 PM
Hello if you get all the numbers listed I may be able to look up to see if it has the starter in the windings or not. I have some old books for Miller Welders and some Onan books.
  • dryrun said thank you
#7 frgccss OFFLINE
frgccss
  • 1 Thanks
  • 3 posts
Posted May 23, 2011 - 10:02 AM
Won't work. Checked with my guy at Miller, Miller engine welders are not generators. they are alternators. Thanks any way. Fgrccss
