Anybody ever tried logging on a gt?
32 replies to this topic
#31 MH81 OFFLINE
Posted October 11, 2016 - 03:52 PM
A 20' log 8" to 4" would tip over 200#
That's a lot of anchor in contact with the ground. Especially with an LT
Might be better at 10'?
  • Greasy6020 said thank you
#32 Leonard VanCamp OFFLINE
Leonard VanCamp
  • 506 Thanks
  • 387 posts
Posted October 11, 2016 - 04:37 PM
If you can't make a logging arch right away something like a stone boat or sled would work, just make sure in has a turned up nose on it. Cut a slot or hole in the middle of the the nose and run the chain you have on the tree through it. Once you have the log pulled on the stone boat or sled, hook a short chain to the sled to make it and the log attached as one unit. The sled will help guide the log over any obstacles. Should look something like this; ========________/--------- (===log) (______/stone boat or sled) (------chain).
#33 shorty ONLINE
shorty
  • 5,463 Thanks
  • 5,256 posts
Posted October 11, 2016 - 04:48 PM
If I understand this correctly, you want to go have fun with your tractors while doing something that offsets the cost. Before I would go get or build anything. I think I would go cut a tree down and see how your tractor can handle say, a 8-10' log in your setting. If it does good, then try a longer log. Once you do a few, you will have a much better feel for what you want and what works best.
