MTD 16 hp. identification help!
mtd 3 point tiller 16 hp
9 replies to this topic
#1 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,117 Thanks
  • 1,208 posts
Posted August 07, 2016 - 02:52 AM
Here is a picture of the tractor that I'm trying to identify.  It comes with a tiller that is driven by a pto shaft.  The decal says its an MTD.  I've noticed that the engines sits on the frame different from my 990. I thought it might be a 960 but I haven't found any 960 pictures that look like this.
My biggest question is will the draft bars and tiller work on my 990?
  • Traill95 and MolonLabe have said thanks
#2 KennyP ONLINE
  • 37,385 Thanks
  • 45,444 posts
Posted August 07, 2016 - 04:10 AM
That looks like the same tiller I had here for TD&H. I would think it would work. But I'm guessing!
  • Mark 149 J. said thank you
#3 Rock farmer OFFLINE
Rock farmer
  • 1,197 Thanks
  • 1,232 posts
Posted August 07, 2016 - 07:08 AM
I think it is perhaps a 992 or 993 from the mid eighties?
Standard trans and manual lift.
That's the generation after the 990's
I don't know that the tiller would work on a 990.
But perhaps with a different length drive shaft it might?
However, I believe your snow plow / dozer blade may hook right up to this tractor!
Joe
#4 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,605 Thanks
  • 1,306 posts
Posted August 07, 2016 - 07:47 AM
Its not a 99x or 760,860,960 series. Not sure on the tiller but it looks like it should work on a 990.
#5 drbish ONLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,357 posts
Posted August 07, 2016 - 08:27 AM
Here is the ipl for,918 and 951 three point hitch which appears to be the same at a quick glance while scanning.also 956,981 and 987-989 tillers.The 956 uses a 27 in drive shaft as noted on the IPL,maybe you can compare the tiller pages to determine if it will interchange
Attached File  mtd3pttiller.pdf   2.7MB   81 downloads
#6 Rock farmer OFFLINE
Rock farmer
  • 1,197 Thanks
  • 1,232 posts
Posted August 07, 2016 - 09:11 AM
I think it's a 918 model 14-918-0
Joe
#7 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,117 Thanks
  • 1,208 posts
Posted August 07, 2016 - 10:36 AM
Kenny what is TD&H?
#8 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,117 Thanks
  • 1,208 posts
Posted August 07, 2016 - 11:09 AM
attachicon.gifmtd3pttiller.pdf
Joe
Thanks for the information!
I down loaded the 918 owners manual and it looks identical to me.
The part number for the LH draft arm is 13130.
The 990 lists the LH draft arm as 10986.
I'm assuming they are different parts unless someone knows how to cross reference these two number.  I've tried and I've had no luck.
I need the draft arms for my 990.  If I can get a tiller as well then that will be a bonus!
Edited by Mark 149 J., August 07, 2016 - 11:12 AM.
#9 Rock farmer OFFLINE
Rock farmer
  • 1,197 Thanks
  • 1,232 posts
Posted August 07, 2016 - 11:28 AM
TD&H is Texas deer and horse, a member here.
No, that three point hitch will not fit a 990.
Joe
#10 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,117 Thanks
  • 1,208 posts
Posted August 07, 2016 - 03:19 PM
Joe
It was worth the try.  Thanks for all of the help!
  • Rock farmer said thank you
Also tagged with one or more of these keywords: mtd, 3 point, tiller, 16 hp
