Onan Fuel Problem
20 replies to this topic
#16 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted August 06, 2016 - 02:26 PM
My brother had the same problem with his Onan, there was crud plugging the outlet from the tank !
I was going to suggest the hose barb on the tank may have a problem...some have a screen on them inside the tank and could be partially clogged make the fuel pump vacuum find that little air leak somewhere.
Good luck and let us know what you found!
  • MH81 and bbuckler have said thanks
#17 secondtry ONLINE
secondtry
  • 1,868 Thanks
  • 1,377 posts
Posted August 06, 2016 - 04:34 PM
    To check fuel flow from the tank I just remove the Fuel line from the pump inlet and let the fuel gravity feed into a clean gas can. with the plastic gas cans enough light gets in to see if fuel is dirty. If all the fuel drains from the tank and it is clean I feel that eliminates dirty tank as a problem.  The previous owner of my 18/6 worked on the carb and reinstalled a gasket upside down. Then apparently decided the fuel pump was defective. removed the fuel pump from the side of the carb and ripped the little brass read valves out reassembled. then installed an electric pump. The gasket being upside down blocked fuel flow to the float valve. The tractor was left to rot for several years before I bought it real cheep. Don
  • ducky and MH81 have said thanks
#18 bbuckler ONLINE
bbuckler
  • 3,431 Thanks
  • 3,046 posts
Posted August 06, 2016 - 07:32 PM
Got the old line off but it will be the morning before I get a new piece.
  • MH81 and Texas Deere and Horse have said thanks
#19 bbuckler ONLINE
bbuckler
  • 3,431 Thanks
  • 3,046 posts
Posted August 08, 2016 - 02:04 PM
New fuel hose on still have to put the seat back on
#20 bbuckler ONLINE
bbuckler
  • 3,431 Thanks
  • 3,046 posts
Posted August 08, 2016 - 08:38 PM
Check to make sure the clamps are tight and the line doesn't have a nick in it also.
The new line fixed the problem I mowed a good piece of the pasture no stalling.
  • ducky and Alc have said thanks
#21 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted August 08, 2016 - 11:47 PM
Glad you got that job DONE!
