Onan Fuel Problem
20 replies to this topic
#1 bbuckler ONLINE
bbuckler
  • 3,433 Thanks
  • 3,047 posts
Posted August 05, 2016 - 08:14 PM
I started having a issue on my 16/6 twin. It will be running fine but after awhile it will get a air bubble in the line and stall out.
I got new clamps on there and it has the tygon line going to the fuel pump. Any clues on what it can be ?
  • chieffan said thank you
  • 14,800 Thanks
  • 15,495 posts
Posted August 05, 2016 - 09:20 PM
Brandon, when you say it's getting air in the fuel line, before or after the fuel pump?
#3 bbuckler ONLINE
bbuckler
  • 3,433 Thanks
  • 3,047 posts
Posted August 05, 2016 - 09:22 PM
Before it go in right in the little piece of tygon line.
#4 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted August 05, 2016 - 09:26 PM
Good question.
Are we sucking air or boiling the fuel (vapor lock)?
  • 14,800 Thanks
  • 15,495 posts
Posted August 05, 2016 - 09:30 PM
Check the barb sticking out of the bottom of your tank to make sure it's not cracked.
  • bbuckler said thank you
#6 bbuckler ONLINE
bbuckler
  • 3,433 Thanks
  • 3,047 posts
Posted August 05, 2016 - 09:31 PM
Good question.
I was wondering if it because the fuel line sit close to the muffler.
#7 bbuckler ONLINE
bbuckler
  • 3,433 Thanks
  • 3,047 posts
Will do
#8 Texas Deere and Horse OFFLINE
  • 14,800 Thanks
  • 15,495 posts
Posted August 05, 2016 - 09:35 PM
I don't remember if your tank is mounted below the seat or under hood? If under seat, it could be a bad pickup in tank also. Had one on a JD318 do that.
#9 bbuckler ONLINE
bbuckler
  • 3,433 Thanks
  • 3,047 posts
It under the seat but it has the fitting on the bottom if I remember right.
Edited by bbuckler, August 05, 2016 - 09:36 PM.
#10 Texas Deere and Horse OFFLINE
  • 14,800 Thanks
  • 15,495 posts
Posted August 05, 2016 - 09:37 PM
Check to make sure the clamps are tight and the line doesn't have a nick in it also.
#11 bbuckler ONLINE
bbuckler
  • 3,433 Thanks
  • 3,047 posts
Posted August 05, 2016 - 09:42 PM
I got to re run the fuel line anyways my dad knocked it loose with his foot and that about the time it start acting up but I added the hose clamps to it all
#12 secondtry ONLINE
secondtry
  • 1,874 Thanks
  • 1,378 posts
Posted August 05, 2016 - 09:51 PM
Checking this out may help, I believe they are very similar.
Fuel Tank Problems on Sears GT18-6
in Sears, Craftsman Tractor Forum
Started by Utah Smitty, Jun 25, 2016  icon_tag.pngsears, gt18, gt18-6, fuel tank
#13 bbuckler ONLINE
bbuckler
  • 3,433 Thanks
  • 3,047 posts
Posted August 05, 2016 - 10:08 PM
How much fuel line is needed ? I think I will replace the old line too.
#14 Texas Deere and Horse OFFLINE
  • 14,800 Thanks
  • 15,495 posts
Posted August 05, 2016 - 10:11 PM
Just get 10' or 12' and you'll have extra. :thumbs:
#15 Lmiller3358 OFFLINE
Lmiller3358
  • 1,480 Thanks
  • 1,421 posts
Posted August 06, 2016 - 05:58 AM
My brother had the same problem with his Onan, there was crud plugging the outlet from the tank !
  • Alc, KC9KAS and bbuckler have said thanks
