3 point tiller
5 replies to this topic
#1 jjln50 OFFLINE
jjln50
  • 11 Thanks
  • 18 posts
Posted August 05, 2016 - 10:25 AM
I am hopefully looking for some plans to convert a tow behind tiller to 3 point hitch.
#2 MNGB OFFLINE
MNGB
  • 5354 Thanks
  • 2603 posts
Posted August 05, 2016 - 12:42 PM
What kind make model of tow behind tiller would this be for a Cat 0 3 pt? 2nd question why a tow behind is pretty easy to use with any tractor regardless of hitch type.
#3 jjln50 OFFLINE
jjln50
  • 11 Thanks
  • 18 posts
Posted August 05, 2016 - 05:50 PM
The tiller is a agi-fab 36 inch. Cat 0 3 point hitch. I want to be able to pick it up at the end of each row and to be able to back up. The tiller only has about 20 hrs on it so hate to spend money to replace. Thanks.
#4 MNGB OFFLINE
MNGB
  • 5354 Thanks
  • 2603 posts
Posted August 05, 2016 - 06:18 PM
Hi I've seen the Agri-Fabs and looked at them but have not had one in the shop, so don't know how one could attach a 3 pt hitch, but I'm sure with some studying and fabricating it could be as for plans I doubt there are any but here again maybe a YouTube  search would come up this something. Maybe a 3/8" thick steel plate mounted under the engine then a 3 pt hitch welded to it you will need to change the linkage for raise and lowering the tiller etc.
  • jjln50 said thank you
#5 jjln50 OFFLINE
jjln50
  • 11 Thanks
  • 18 posts
Posted August 05, 2016 - 07:27 PM
Thank you MNGB never thought of a plate under engine. Looks like it might be doable (sp)
  • MNGB said thank you
#6 MNGB OFFLINE
MNGB
  • 5354 Thanks
  • 2603 posts
Posted August 05, 2016 - 07:43 PM
Here's some pix of a Sears walk behind I converted to a sleeve hitch could easily have been 3 pt, just to give you an idea how to start. I use this tiller with the PK using a sleeve hitch adapter on the 3 pt.
  • Alc, Cvans and jjln50 have said thanks
