Again!
12 replies to this topic
#1 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted August 04, 2016 - 03:39 PM
B&S opposed 18 just ate another starter drive gear. At this rate I may as well pick up a box of them. If recalled correctly, this is the 4th one this year. Think it's time to just buy an entire NEW starter as it appears this one has a tad bit of play in the bearing area.
  • rustyoldjunk said thank you
#2 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,977 Thanks
  • 9,624 posts
Posted August 04, 2016 - 04:00 PM
Are these plastic? Is there a metal one that will substitute?
  • Phluphy said thank you
#3 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted August 04, 2016 - 04:18 PM
Play in the brass bushings will eat the nylon gears. (The top bushing usually goes first) Three options.
1. Replace the Starter.
2. Talk with a Generator / Alternator shop on replacing the bushings, or remanufacture the starter.
3. Buy a bag of gears (I keep 1 - 2 hanging around for mine)
DO NOT use a metal gear or you will be looking for a replacement flywheel gear or new flywheel.
Edited by larrybl, August 04, 2016 - 04:20 PM.
  • rustyoldjunk, Gtractor and Phluphy have said thanks
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted August 04, 2016 - 04:20 PM
Those nylon gears really suck
#5 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted August 04, 2016 - 04:21 PM
If a new starter, make sure it is the same length as the old or you will need to trim the shroud like I had to.
#6 boyscout862 ONLINE
  • 12,541 Thanks
  • 9,039 posts
Posted August 04, 2016 - 04:23 PM
Rebuild the starter with new bearings. Put on the new bendix gear set. Remove burrs from the teeth of the ring gear. When installing it, be sure to get the alignment right. I've seen this with worn starters and damaged ring gears. Correcting the problems stopped any further problems. The plastic gears are designed to be destroyed so that more expensive parts are spared. I used to get the gears in boxes of 10. Good Luck, Rick
#7 jms180 ONLINE
jms180
  • 1,477 Thanks
  • 1,545 posts
Posted August 04, 2016 - 05:00 PM
You are correct fiber gear with aluminum flywheel
#8 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted August 04, 2016 - 06:14 PM
Perhaps nylon. Thinking plastic though. Definitely would not go with metal. Gears are less expensive and labor intensive than ring gear replacement.
#9 Cvans ONLINE
  • 6,461 Thanks
  • 6,055 posts
Posted August 04, 2016 - 06:15 PM
For me it was not the expense of the gear (they are reasonable) it was the fact that the engine had to be pulled to get at the starter.  :mad2:
#10 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted August 04, 2016 - 06:21 PM
My finance manager just told me to buy a new starter. Works for me. :)
  • MH81 and Cvans have said thanks
#11 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted August 04, 2016 - 06:23 PM
Length? As in overall, housing or?
#12 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted August 04, 2016 - 06:27 PM
The starter comes out of this thing (craftsman II gt) in less than 3 minutes, as long as the bolt clearance opening is lined up under the flywheel.
#13 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted August 04, 2016 - 06:53 PM
Sounds like this. https://www.youtube....h?v=NKnos9MXqNg
Post 116 - 118 here shows the longer starter issue and how to correct it. http://gardentractor...-hulk-ii/page-8
  • boyscout862 and Phluphy have said thanks
