317 mower deck, help
14 replies to this topic
#1 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted August 04, 2016 - 10:45 AM
I have tried to find a good video showing how to mount up a deck under a JD317 and so far nothing. I did find some on the 318 but some of the stuff does not look the same.
If someone here happens to know of a link showing the mounting and leveling of a 317 deck would you please post it??
#2 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted August 04, 2016 - 11:02 AM
First off... which deck do you have?  WAs it on the tractor before?
The 41 deck uses longer draft arms than the 48 deck.  Belt used depends on deck and engine too. (IIRC there are total of 4 different belts used depending on the combination)
Edited by Trav1s, August 04, 2016 - 11:15 AM.
#3 hdg4400 ONLINE
hdg4400
  • 284 Thanks
  • 348 posts
Posted August 04, 2016 - 12:22 PM
victor3ranger:
Check your PMs. I've sent you something that may help.
Harlan
#4 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted August 04, 2016 - 01:22 PM
Thanks guys. I have a hand full of decks, I am pretty sure I have the one that came from the 317 but still unsure about that.
The motor is a Onan and I will have to get the numbers off the decks and post them tomorrow.
#5 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted August 04, 2016 - 01:30 PM
For what it's worth - a deck for the 120/140/300 series machine will have the drive pulley above the center spindle.
Harlan's hook-up will also help!
#6 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted August 04, 2016 - 03:28 PM
Travis, I hate to sound stupid but what does it mean to have the drive pulley above the center spindle??
#7 KennyP ONLINE
  • 38,352 Thanks
  • 45,921 posts
Posted August 04, 2016 - 03:38 PM
The drive pulley is on the center spindle?
#8 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted August 04, 2016 - 04:20 PM
Yes, the drive pulley is on the center spindle as opposed to the SF/200 series which attaches to a separate pulley towards the back of the deck.  The PTO belt comes down from the crank, thru the mule drive, and attaches to the large pulley that is above the belt cover. This is a 41 (same dimensions as a 39 from the SF/200 series)
Edited by Trav1s, August 04, 2016 - 04:22 PM.
#9 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted August 04, 2016 - 04:21 PM
Another for reference - 48 which is the same dimensions as a 47 from the SF/200 series
#10 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted August 05, 2016 - 08:34 AM
Trav1s,
Looking at both of your pictures I think I see that in the first picture the attaching arms at the tractor end only have a hole in them, the second picture the arms have the quick attach as part of the arm.
Am I correct in thinking that the 317 only uses the arms like the ones shown in the first picture??
If so then I only have decks that have arms like the ones in the second picture.
#11 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted August 05, 2016 - 09:00 AM
That difference is related to the age of the tractor.  The first pic is the mount type used on the 120/140/300/312/316K and the other is the 314/317 design.  You can swap arms to either deck (design is the same) to work on the tractor.  I believe you can swap mounts on the tractor too but am not positive.
#12 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted August 05, 2016 - 10:20 AM
Mine must be a earlier 317 because the quick connects are on the tractor frame.
If I had the other arms to replace the quick connect arms on my decks I might be able to make one work.
Not sure where to get those at around here though.
#13 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted August 05, 2016 - 10:37 AM
My 120 and 312s have the earlier style which work fine for me.  If that's what ya got then run it.
#14 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted August 05, 2016 - 02:24 PM
Between the two types, is there a difference in length of the lift arms??
#15 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted August 05, 2016 - 09:56 PM
Not that I am aware of since that would impact belt length and JDParts makes no reference to arm type when ordering belts.
