My welds will improve immensely
20 replies to this topic
#1 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted August 03, 2016 - 10:24 PM
I got this from the wife for my birthday, (which isn't till the end of the month, but it was on sale). Preliminary tests show a vast improvement in vision over my 30 year o9ld flip helmet.
I can't wait to do some more welding.
Just need someone to bring me some work
  • MH81, hamman, wvbuzzmaster and 10 others have said thanks
#2 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted August 03, 2016 - 10:32 PM
Those auto dimming welding masks are nice... Unless it is extra sunny outside, then they get confused and act like a turn signal light...
I like mine, makes it easier just starting out welding. I was and am still not great at stick welding, but MIG is pretty slick and already laying down decent MIG welds thanks to autodimming welding mask being one less thing to think about. Only other problem I had with the auto dimming mask is if you use a faceshield for grinding (metal prep) and you are going back and forth between welding and grinding. You definitely miss the auto dimming feature when you forget to switch masks before welding haha.
  • Alc, HDWildBill, Chopperhed and 1 other said thanks
#3 Cvans ONLINE
  • 6,463 Thanks
  • 6,056 posts
Posted August 03, 2016 - 10:55 PM
For 40 years I flipped those helmets up and down. For the last ten I have had an auto darkening helmet and I still flip it up between welds. And I try to flip it down before the weld. I don't think I will ever learn.  :(
  • MH81, Alc, wvbuzzmaster and 5 others have said thanks
#4 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted August 03, 2016 - 11:45 PM
This mask has a switch for grinding mode, but yes , the sensitivity adjustment can cause a few blackouts when looking out the door or looking at a light. The real plus for me is the shade adjustment, I can finally see the puddle clearly, it's been years since I could do that. The speed sensitivity is great, all I see when I strike an arc is a couple of orange sparks. The most important thing for me is being able to position my rod or torch, and not having to flip the helmet down and lose orientation.
Edited by Chopperhed, August 03, 2016 - 11:49 PM.
  • Alc, wvbuzzmaster, michael.kitko and 1 other said thanks
#5 Alc OFFLINE
  • 6,745 Thanks
  • 7,397 posts
Posted August 04, 2016 - 05:22 AM
Is the " grinding mode" a new feature on these auto darkening helmets ?
  • Chopperhed said thank you
#6 KennyP OFFLINE
  • 37,477 Thanks
  • 45,490 posts
Posted August 04, 2016 - 07:00 AM
I would not use a welding helmet for grinding as the sparks will mess up the outside plastic cover so that you have trouble while welding. Get a full face shield for grinding!
  • Alc, Cvans, Chopperhed and 2 others have said thanks
#7 chieffan ONLINE
  • 9,579 Thanks
  • 6,413 posts
Posted August 04, 2016 - 07:22 AM
I love mine.  But like has been said, they are sensitive to sun and bright light.  Just getting to where I can do some wire welding decent.  Learned on a stick and still use it for the heavier stuff over 5/16 - 1/4 "  Use the wire for the lit stuff.
  • Chopperhed and holdenboy1960 have said thanks
#8 HDWildBill OFFLINE
  • 8,975 Thanks
Posted August 04, 2016 - 07:32 AM
What make helmet is it?  I have an HF helmet and I can't see a darn thing when I'm welding.
  • Chopperhed and michael.kitko have said thanks
#9 Cvans ONLINE
  • 6,463 Thanks
  • 6,056 posts
Posted August 04, 2016 - 09:57 AM
I haven't had real good luck with these helmets when it gets below freezing. Hopefully the newer ones are better.
#10 KC9KAS ONLINE
KC9KAS
  • 5,328 Thanks
  • 4,672 posts
Posted August 04, 2016 - 01:54 PM
I could probably break something so you could weld it! :bigrofl:
  • Alc and Chopperhed have said thanks
#11 Jazz OFFLINE
Jazz
  • 2,302 Thanks
  • 1,404 posts
Posted August 04, 2016 - 08:30 PM
Grinding mode is a nice touch, you will enjoy welding much more. Having a good view improves welds. LED flashlight fastened to helmet for dim areas is handier than a trouble light.
#12 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted August 05, 2016 - 07:12 AM
http://www.princessa...met/A-p8540650e
  • HDWildBill said thank you
#13 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted August 05, 2016 - 07:13 AM
I never weld outside so it shouldn't be an issue
  • Cvans said thank you
#14 FrozenInTime OFFLINE
FrozenInTime
  • 650 Thanks
  • 399 posts
Posted August 27, 2016 - 03:53 PM
You'll enjoy it!  I use auto-darkening helmet for my messes... LOL.  I just picked up a new Hobart, can't wait to use it.  My other helmet starts out great but as I weld, it gets darker and darker until I can't see.  I use mine when grinding too.
#15 michael.kitko OFFLINE
michael.kitko
  • 505 Thanks
  • 462 posts
Posted August 27, 2016 - 07:53 PM
Looks good. Not really my cup of coffee, but gears non the less. For anyone out there, make sure you stay away from the super cheapies. Guys I know bought the cheap ones and often times get flashed or they have tired eyes at the end of the day. Just a word of advice.
Mike "Squirrelly" Kitko
