bios access
system settings boot order
4 replies to this topic
#1 secondtry OFFLINE
secondtry
  • 1,906 Thanks
  • 1,390 posts
Posted August 03, 2016 - 02:19 PM
 I have a Gateway NE66R31U lap top which has already don the 10 upgrade. I am looking for info on about how to access BIOS. So far the only way I have been able to do this is to remove the hard drive. If any one has any special tricks I would be very grateful.   Don
#2 Trav1s ONLINE
Trav1s
  • 3,314 Thanks
  • 4,367 posts
Posted August 03, 2016 - 04:05 PM
Meaning you are looking how to access the bios setup?
User Guide - Gateway
  • HDWildBill said thank you
#3 secondtry OFFLINE
secondtry
  • 1,906 Thanks
  • 1,390 posts
Posted September 01, 2016 - 04:03 PM
Tried the link above with no luck. The computer came with windows 8 and had been upgraded to 10. This apparently disables normal bios access.  I found a way into bios after booting into windows 10. Unfortunately I didn't document this If I remember properly it was through settings / troubleshooting.  Once I accessed bios I got all involved in dual booting Linux cinnamon and exploring that. Forgot all about this post so now I'm no help. I have solved my problem. If I can backtrack and figure out how I will update here.  Don
#4 OldBuzzard ONLINE
OldBuzzard
  • 7,027 Thanks
  • 4,792 posts
Posted September 01, 2016 - 06:42 PM
From what I can find, you should be able to get into the BIOS settings by tapping the F2 key immediately after powering on the computer.
Don't so just one tap, do a series of them and at a fairly fast rate.
You should hear a beep that tells you that you are entering the BIOS.
If you aren't successful, power off and try again.
  • Trav1s said thank you
#5 Trav1s ONLINE
Trav1s
  • 3,314 Thanks
  • 4,367 posts
Posted September 03, 2016 - 06:50 AM
My experience with Win10 machines is that it is hard to access the bios, especially if it is running a SSD drive.  Timing is everything.
