Fried Ignition... HELP!
15 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted May 19, 2011 - 02:32 PM
Well, I finished the bare bones rewire of the Caterpillar and tried to start it... Well.... It would not start... and not it will not start.... after I heard sizzling coming from where my ignition wires come out out of the engine..... Well, Dad and I tested the switch and believe that it is a grounded to kill it setup, meaning it should not get power to that wire.... which I gave it.... HELP!! It is a 1988 Briggs and Stratton opposed twin.... I hope I don't have to pull the flywheel cause that means I would have to pull the engine...... anyone able to help???
#2 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted May 19, 2011 - 03:24 PM
Would like to add that it is sizzled enough to burn out a 30 amp fuse instantly....
I have gone back and tested, I have no spark at all, so I need help....
#3 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted May 19, 2011 - 04:20 PM
Casey call me
#4 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted May 19, 2011 - 04:26 PM
sounds like you burned two diodes;on the kill wire by powering it. unhook all wires , jump the starter directly and check for spark, call me. Shawn
#5 olcowhand ONLINE
  • 42,498 Thanks
  • 31,835 posts
Posted May 19, 2011 - 04:49 PM
More than likely, the coils are fried.
#6 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted May 19, 2011 - 05:07 PM
No spark, no run, something definitely is fried. Shawn and I determined it to most likely be a Magnetron setup. As far as getting to it.... the engine will most likely have to get out....
#7 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted May 19, 2011 - 05:38 PM
I think I found the ignition coil I need, part number 394891
Amazon.com: Briggs & Stratton 394891 Ignition Coil For L-Head Twin Engines: Patio, Lawn & Garden
Is this correct?
#8 Bolens 1000 ONLINE
  • 15,300 Thanks
  • 18,236 posts
Posted May 19, 2011 - 05:40 PM
Link dosent work
#9 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted May 19, 2011 - 05:46 PM
Link dosent work
Just tried it myself and it is working for me.
#10 Bolens 1000 ONLINE
  • 15,300 Thanks
  • 18,236 posts
Posted May 19, 2011 - 05:47 PM
It works now :D
#11 MH81 OFFLINE
Posted May 19, 2011 - 06:01 PM
Casey, so sorry to hear it. That switch must be for a powered ign system. Better do a continuity check on it before going much farther. Is it the same pt number or a direct replacement?
#12 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted May 19, 2011 - 06:06 PM
The new switch it for powered ign system, and I thought that is what I had, remember, I bought an IH truck ign switch. I would have thought a red flag would have come up with someone reading my rewire thread to mention something if I had the wrong plan. Mixing and matching parts is tough. Ah well, guess I won't make that mistake again.
The magneto I linked looks to me a replacement for another part number that is the right part number, but it does come up for my engine. My engine is a 422437-1209 if anyone wants to doublecheck that part for me.
#13 caseguy OFFLINE
  • 1,629 Thanks
Posted May 19, 2011 - 06:37 PM
...My engine is a 422437-1209 if anyone wants to doublecheck that part for me.
Casey, I checked out partstree and using that engine model number I came up with Briggs and Stratton 394891 Armature-Magneto. I put a link to the page as well. Click Here Hope this helps.
#14 Alc ONLINE
  • 7,132 Thanks
  • 7,533 posts
Posted May 19, 2011 - 07:06 PM
Sorry to hear about your ignition wires .Hope there's not too much damage , Al
#15 Bolens 1000 ONLINE
  • 15,300 Thanks
  • 18,236 posts
Posted May 19, 2011 - 07:18 PM
Will the one circled work?
