Fuel shutoff question
14 replies to this topic
#1 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted August 02, 2016 - 04:18 PM
If a metal fuel shutoff leaks around the handle when open, could it let enough air into the system to keep the engine from starting?  In this case the shutoff is right by the carb on a Briggs and Stratton.
  • chieffan said thank you
#2 Bolens 1000 ONLINE
  • 14,890 Thanks
  • 18,097 posts
Posted August 02, 2016 - 04:38 PM
I wouldnt think so, the carb will stay full of gas either way.
#3 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted August 02, 2016 - 05:16 PM
I wasn't sure, I have seen cracked lines do what I thought this might.
#4 John Arsenault ONLINE
John Arsenault
  • 2,371 Thanks
  • 1,143 posts
Posted August 02, 2016 - 05:55 PM
That depends on if there is a positive vacuum like a fuel pump would add. If its just gravity fed a crack line will just leak.
  • adamjd200 and chieffan have said thanks
#5 chieffan ONLINE
  • 9,526 Thanks
  • 6,393 posts
Posted August 02, 2016 - 06:48 PM
I would thing a fuel shut off would want to be at the tank and not the carb.  If anything goes wrong between the shut off and the tank  your going to loose gas with the shut off at the barb.  Just my opinion.
  • adamjd200 said thank you
#6 John Arsenault ONLINE
John Arsenault
  • 2,371 Thanks
  • 1,143 posts
Posted August 02, 2016 - 06:53 PM
Depends on the set up, I have seen them under the tank, and yet just under the carb......I agree though directly under tank makes sense to me.
#7 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted August 02, 2016 - 07:30 PM
I've had it happen on gravity feeds before, usually Briggs or Tech. engines.
This is on my Yazoo Red Rider, and the shutoff is literally threaded into the carb inlet, pain it the but.  As a side note, the tank is plastic.
#8 secondtry ONLINE
secondtry
  • 1,676 Thanks
  • 1,279 posts
Posted August 02, 2016 - 11:02 PM
Many newer Honda engines have a fuel shutoff on the carb. The fuel shutoff is not generally intended to save you in case of neglected or destroyed fuel lines. It is to prevent filling the crankcase with gas in the event the float malfunctions. If a gravity feed system is sucking air there must be something wrong with gravity. Don
  • adamjd200 and propane1 have said thanks
#9 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted August 02, 2016 - 11:10 PM
Let me rephrase my earlier comment, I've had engines w/ gravity feed and bad lines refuse to start, when the fuel line was replaced it then started, usually bad around the ends, why it makes a difference idk., they weren't leaking severely either.
  • secondtry said thank you
#10 secondtry ONLINE
secondtry
  • 1,676 Thanks
  • 1,279 posts
Posted August 03, 2016 - 12:55 AM
     Old fuel lines come apart internally swell and cut off fuel flow, I have had that happen. When I need a 6" of fuel line I buy 10 feet. It never goes to waste.  Don
  • propane1 said thank you
#11 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted August 03, 2016 - 09:33 AM
 I buy it by the 25ft roll, cheaper and I use a lot of it.
#12 secondtry ONLINE
secondtry
  • 1,676 Thanks
  • 1,279 posts
Posted August 03, 2016 - 10:17 AM
    I live in Washington State. Practically a different country. Could be I just don't shop at the right place but locally I have never seen it in a 25' roll Don
#13 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted August 03, 2016 - 03:44 PM
I buy mine on ebay, good quality gas line, and made in the USA!
#14 Bolens 1000 ONLINE
  • 14,890 Thanks
  • 18,097 posts
Posted August 03, 2016 - 03:56 PM
I sell USA made line by the foot or by the box if you need any :wave:
#15 secondtry ONLINE
secondtry
  • 1,676 Thanks
  • 1,279 posts
Posted August 03, 2016 - 07:08 PM
     Recently stocked up but I will keep you in mind. Don
