Yazoo PTO-B 48 inch mower
yazoo pto-b yazoo mower jerry clower special!
35 replies to this topic
#31 Cvans OFFLINE
  • 6,649 Thanks
  • 6,130 posts
Posted August 18, 2016 - 05:09 PM
Are copies of the owners manual available?
#32 KennyP ONLINE
  • 38,417 Thanks
  • 45,945 posts
Posted August 18, 2016 - 05:37 PM
It's uploaded here.
  • Cvans said thank you
#33 Cvans OFFLINE
  • 6,649 Thanks
  • 6,130 posts
Posted August 18, 2016 - 07:45 PM
That's a big manual. On the cover it appears the guide rollers are running on the ground,
How does it ride? Your seated in an unusual position.
#34 KennyP ONLINE
  • 38,417 Thanks
  • 45,945 posts
Posted August 19, 2016 - 06:21 AM
If you look at that deck and mine, there are major differences. Across the front, mine has chain hanging. Also, how the lift cable and springs attach. That's why I think mine is an earlier model.
#35 KennyP ONLINE
  • 38,417 Thanks
  • 45,945 posts
Posted August 20, 2016 - 05:07 PM
I saw an issue when mowing. This is a left hand discharge deck. At the left rear castor, a piece of metal was missing, causing the grass clippings to blow back onto the drive unit. (This is a CCW cutter assembly) So today I pulled the deck loose and made a piece to close this off. Should help keep the clippings off the 'tractor' unit.
  • olcowhand and Alc have said thanks
#36 KennyP ONLINE
  • 38,417 Thanks
  • 45,945 posts
Posted August 23, 2016 - 05:47 PM
I have been looking at the lift handle on this. As it is, you have to push the handle in to unlatch and lower the deck. Then you have to pull it out to lock the handle in the lowered position. Not a good situation. I studied it for a bit and decided I could make it work better.
What I did was take the lower latch I just made and reversed it. Then I took the handle off and made a new piece where it swiveled. Waiting for rust reformer to dry before I can put it back together.
  • olcowhand said thank you
Also tagged with one or more of these keywords: yazoo pto-b, yazoo mower, jerry clower special!
