Tecumseh H70 Governor link
12 replies to this topic
#1 IamSherwood OFFLINE
  • 8,382 Thanks
  • 7,696 posts
Posted May 19, 2011 - 11:45 AM
Any have a good picture handy of the carb and governor linkage?
Thanks
#2 JDBrian OFFLINE
  • 9,594 Thanks
Posted May 19, 2011 - 07:36 PM
Did you download the Tecumseh Basic Service Information manual in the engine manuals section. I think it has a section on governors.
#3 IamSherwood OFFLINE
  • 8,382 Thanks
  • 7,696 posts
Posted May 19, 2011 - 07:56 PM
Yes, I have that bible, but the drawings aren't really clear enough. It's helpful, but not quite enough.
Thanks
#4 NYMalloys OFFLINE
NYMalloys
  • 28 Thanks
  • 43 posts
Posted June 04, 2011 - 06:53 PM
I have the carburetor and fuel tank off of my MF-7, but here are two pictures. One shows the link rod connected to the tab that extends off of the U-shaped bracket that mounts to the governor, the tab that is reoriented when adjusting the governor setting. The second shows the carburetor throttle tab with an arrow indicating the hole for the link rod. If this isn't what you were looking for, let me know and I can probably get a picture of the system assembled (minus the fuel tank which still needs work).
#5 caseguy OFFLINE
Posted June 04, 2011 - 07:05 PM
I could use a pic of that assembly when you get a chance. Thanks!
#6 IamSherwood OFFLINE
  • 8,382 Thanks
  • 7,696 posts
Posted June 04, 2011 - 07:10 PM
I had made up my own rod, but not sure if the length was correct.
Wasn't runnng right, so I ordered a link from Tecumseh.
Will post pic once I get it, and installed.
  • caseguy said thank you
#7 NYMalloys OFFLINE
NYMalloys
  • 28 Thanks
  • 43 posts
Posted June 04, 2011 - 07:25 PM
On the setup on my engine, the length of the rod wouldn't make much a difference, because of the way you can move that little tab that projects from the governor U bracket. I don't remember the exact procedure (I'll need to brush up on it shortly when I connect mine) but you loosen the retaining screw on the tab, hold the throttle full open and the governor at full speed position and then tighten that tab screw. If I remember this allows for a pretty significant amount of play (at least 1 cm) which would compensate for different rod lengths. I am not sure if this type setup was employed on all the Tecumseh H-70's.
  • MH81, caseguy and IamSherwood have said thanks
#8 caseguy OFFLINE
Posted June 04, 2011 - 08:02 PM
I'm dealing with an HH60 and I'm using the setup you are talking about. The engine sounds like it's gonna scatter if I open the throttle all the way up though (revving WAY too high) Any suggestions? Pics of the rest of the setup might help if you have or can get them.
#9 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted February 08, 2015 - 09:47 AM
Did anyone ever get a picture cause i could really use one
  • IamSherwood said thank you
#10 IamSherwood OFFLINE
  • 8,382 Thanks
  • 7,696 posts
Posted February 08, 2015 - 10:08 AM
This setup works.
That's on a MF7
#11 IamSherwood OFFLINE
  • 8,382 Thanks
  • 7,696 posts
Posted February 08, 2015 - 10:12 AM
From the MF7 manual
#12 IamSherwood OFFLINE
  • 8,382 Thanks
  • 7,696 posts
Posted February 08, 2015 - 10:24 AM
And on another MF7
It had the wrong spring when I got it.
Correct spring at idle.
At wide open.
The linkage ratios are out of wack on these MF7s, so
you'll only get this much travel on the throttle lever, when at wide open.
Or, maybe I'm missing something, but I've never had any luck with it.
#13 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted February 08, 2015 - 12:42 PM
That's got governor set on my Dozer works great now I think it has some dirt in the carb cause it has to run on half choke
