Briggs 8R6 Governor Issues
5 replies to this topic
#1 GTpicker01 OFFLINE
GTpicker01
    GT Addict
  • 706 Thanks
  • 593 posts
Posted August 01, 2016 - 10:19 AM
I have this 8R6 Briggs on my walk behind garden tractor and for some reason when I put it back together the governor doesn't work now. When I took the engine off the it to restore it, the governor worked fine so I'm thinking I didn't hook something up right. Now, I put everything back as the book states, but maybe I'm missing something or the governor blade is stuck. I am including a pic you can zoom in on to see if I have everything back together correctly.
Thanks in advance guys!
#2 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted August 01, 2016 - 04:05 PM
Check your carb linkage for anything binding
#3 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted August 01, 2016 - 04:27 PM
Your picture is too small to be of any help.
Look at Figure B20 on page 38 of this manual:
http://gardentractor...-models-568abn/
  • Bolens 1000 said thank you
#4 GTpicker01 OFFLINE
GTpicker01
    GT Addict
  • 706 Thanks
  • 593 posts
Posted August 01, 2016 - 08:19 PM
This better?
#5 Bruce Dorsi ONLINE
Bruce Dorsi
  • 3,915 Thanks
  • 2,451 posts
Posted August 01, 2016 - 09:22 PM
Much better pics!!!
It appears you have 3 connections to the carb shaft -- there should only be two.
The governor spring and the air vane governor connections are correct, but it appears the throttle cable (?) is also connected there.
The throttle cable should cause tension on the governor spring which opens the carb butterfly, increasing engine speed.  ......When the engine speeds is fast enough to activate the air vane governor, it counteracts the spring tension and closes the carb butterfly slightly to decrease the engine speed.
When everything is operating properly the air vane and spring keep the engine speed pretty constant, with very little fluctuation.
  • GTpicker01 said thank you
#6 GTpicker01 OFFLINE
GTpicker01
    GT Addict
  • 706 Thanks
  • 593 posts
Posted August 02, 2016 - 07:11 AM
Ya know when I got to looking at this last night really close I thought this might be the case!
