I must say I am less than pleased with my Stihl 170 chain saw. I bought one because of their supposedly great reputation. I didn't even run a gallon of fuel through the saw and the coil failed. Fortunately it was under warranty. I am probably just starting on my 3 gallon of fuel and the saw lost power. Turns out the spark arrestor screen was plugged with carbon. I am using Stihl Ultra oil. Is this normal for this saw? Anyone else have a similar problem with the spark arrestor?
Stihl 170 Chain Saw Carbon problem
#1
ONLINE
Posted July 31, 2016 - 10:40 PM
- chieffan said thank you
#2
OFFLINE
Posted August 01, 2016 - 12:55 AM
- earthgrinder said thank you
#3
OFFLINE
Posted August 01, 2016 - 06:35 AM
A plugged screen is usually caused by too much oil mixed in the gas.
Mike
#4
OFFLINE
Posted August 01, 2016 - 07:23 AM
I been running stihl saws for the past 10 years chainsaw carving the little home owner model mentioned is my daily go to saw. There is not another saw like it on the market. Its super light and very reliable. The little screen thing is common , I toss mine out from day one however if I don't remember to do that when I but a new say I usually get a month or so before it starts to clog up, so maybe you have to much oil in your mix or you are running it like my wife does....haha
This saw does not need to be babied , as pointed out its listed as a "homeowner saw" but I can tell you first hand its the best homeowner saw on the market, as long as you have good quality fresh fuel and a good 2 stroke mix you should not be able to hurt it.
I have never in all my 10 years never had a coil go on any of my stihls, to be honest I can list all the problems I have had .1 Screen clogged. 2 Broke a rubber engine mount (I am aggressive) 3. broken a fuel line. Not the saws faulty but bars and chains are my biggest expense.
I have owned the professional husqvarna saws and they are close to the reliability of Stihls home owner models , but stay far far away from the Chinese made huskys they are junk, I killed one of those in 2 months.
Trust me when I tell you you will be fine with that stihl.
The above was just one wholesale order all cut with Stihl saws anything small was done in its entirety with the smaller homeowner model because its the lightest most reliable saw around.
- earthgrinder, MH81, Alc and 4 others have said thanks
#5
ONLINE
Posted August 01, 2016 - 08:41 AM
We have gone to the Clay County Fair for over 10 years. Chain saw artist is the for the whole 10 days. He has a rack full of none less than 15 Stihl chain saws. I have 2 myself, one being about 15 year old. Have no problems with any of them other than the normal ,maintenance items. That is saying something for Stihl Chain Saws. One of the best, if not the best.
- earthgrinder and jpackard56 have said thanks
#6
OFFLINE
Posted August 01, 2016 - 09:37 AM
Another note, stihl requires a high octane fuel. Using a lower grade fuel can cause reliability issues. Ask me how I know haha. Although extreme, I run a mixture of 93 and 110 Cam2. I have 110 on tap 5 minutes from my house (bonus of living 15 minutes from a drag strip). I also run stihl synthetic. 40:1 in my older (041av super, 041av Farm boss, 015l). 50:1 in my MS361. It really likes the high octane fuel.
Eric
Edited by dropped82, August 01, 2016 - 09:38 AM.
- earthgrinder and Alc have said thanks
#7
ONLINE
Posted August 02, 2016 - 03:24 PM
I also have a small collection of stihl saws. Never an issue. Sometimes some minor tuning is needed but nothing major. All my saws are without the screen. You may have to turn the mixture screw a slight bit to accommodate for the loss of backpressure. Not much if at all though. Plus your carb has limiters on it so it'll only go so far.
Eric
Carburetor in non- adjustable. Only screw is for idle rpm. I am using Stihl Ultra with mid grade gas as recommended in the manual.
#8
OFFLINE
#9
ONLINE
Posted August 11, 2016 - 10:05 PM
Spark arrestor screens get clogged. If they weren't catching anything, they wouldn't be working. Watch the oil mix. Watch dirt daubers building nests in the muffler. Stihls usually have a special fuel to run in the first tank for break-in.
I will probably need one more saw in my lifetime. It will definitely be a Stihl.
#10
ONLINE
Posted August 11, 2016 - 10:08 PM
Look at all of the Alaskan based reality shows. Every one of the homesteaders, cabin builders, etc have Stihl saws. I've seen one Husqvarna in use. That says a lot.
#11
ONLINE
Posted August 12, 2016 - 07:56 PM
It is good to hear all of the satisfied users.
#12
OFFLINE
Posted August 12, 2016 - 08:37 PM
FIL has two older ones that are consumer designed units. He has had great luck as well.
The surprise in our saws came a a freebie that I gave no respect at first. It has proved me wrong.
Little Homelite made by (Ryobi?) that looks similar to this
It's light, easy starting, powerful and it was second hand at 8-10 years old. Best feature? Easy chain tightening.
I would buy another of either.
#13
OFFLINE
Posted August 12, 2016 - 08:39 PM
#14
ONLINE
Posted August 13, 2016 - 09:17 PM
I bought my Stihl at a local dealer.
#15
OFFLINE
Posted August 13, 2016 - 09:58 PM
