Got a 1200
9 replies to this topic
#1 64fleetside OFFLINE
64fleetside
  • 189 Thanks
  • 98 posts
Posted July 31, 2016 - 06:59 PM
Scored a 1200 for a Craftsman snowplow and rear sleeve hitch and lift for same Craftsman.
  • Alc, boyscout862, Dieselcubmike and 2 others have said thanks
#2 Buddy ONLINE
Buddy
  • 207 Thanks
  • 122 posts
Posted July 31, 2016 - 07:17 PM
You did good.
#3 EricFromPa ONLINE
EricFromPa
  • 3,552 Thanks
  • 3,076 posts
Posted July 31, 2016 - 07:28 PM
SWEET Manual Cubs are my favorite.No hydro BS to worry about.
  • boyscout862 and Dieselcubmike have said thanks
#4 dodge trucker ONLINE
dodge trucker
  • 2,313 Thanks
  • 3,025 posts
Posted July 31, 2016 - 09:02 PM
yup I have a 1200 as well, about #3 on the depth chart to get its time in the garage.... mine needs the motor pulled, flipped over and the governor gear put back into place, mine came to me with the governor gear retaining screw laying on the frame alongside the engine.... weird.
#5 64fleetside OFFLINE
64fleetside
  • 189 Thanks
  • 98 posts
Posted July 31, 2016 - 09:42 PM
This thing is really pretty clean, rear tires nice, runs clutch is good even the parking brake held it in place in the pickup on the ride home. Cranked up with a new plug. Carb needs built.
#6 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted July 31, 2016 - 10:26 PM
The quiet lines are one of my favorite models of the cub cadet line
#7 EricFromPa ONLINE
EricFromPa
  • 3,552 Thanks
  • 3,076 posts
Posted July 31, 2016 - 11:36 PM
If it has a Walbro carb go find your self a good used Kohler Carter #26 carb for on it.Much much much better carb and very easy to clean and tune.
#8 BNK OFFLINE
BNK
  • 1,095 Thanks
  • 495 posts
Posted August 01, 2016 - 07:06 AM
Good find for sure and trade.
#9 64fleetside OFFLINE
64fleetside
  • 189 Thanks
  • 98 posts
Posted August 31, 2016 - 06:24 PM
Got my clutch plates turned, driveshaft is good just need new t/o brg and some pins. Prolly a new disc since Im here. Replaced head gasket and trued head, cradle mod, made a muffler clutch and using some sway bar engine mounts on top. Combustion chamber was really clean, crosshatching still visible in the bore.
Eric you are correct abt a Walbro my 129 had one, all mine are Carter now.
  • BNK said thank you
#10 64fleetside OFFLINE
64fleetside
  • 189 Thanks
  • 98 posts
Posted September 29, 2016 - 08:10 PM
Got a new throwout bearing, used the old upper mounts as lowers and sway bar bushings as uppers, new head gasket, did the cradle mod and built a muffler crutch. Fired up and runs fine but smokes a bit.
