300 repair an rebuild
37 replies to this topic
#31 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted December 24, 2016 - 11:08 PM
My goal has been an addition with a wood stove but nothing as of yet
Sent from my SM-S820L using Tapatalk
  • Trav1s said thank you
#32 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted December 31, 2016 - 05:49 PM
Well today I made more progress an i used steel wool an motor oil the clean the steering column housing.20161231_162943.jpg 20161231_162949.jpg 20161231_162956.jpg 20161231_165504.jpg 20161231_165510.jpg
  • Trav1s and Kster526 have said thanks
#33 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted October 23, 2017 - 07:19 PM
Well guys a major update for this project finally the motor is rebuilt an back in the frame with new rings new ignition switch new ground from the frame to the block new fuel line an a inline filter. I did run into an issue though when i went to start it the starter only clicks it wont roll the motor over an if it does not a full revolution, ive tried the 3 known good starters i have checked all my connections with a volt meter. So far everyone i have talked to has said that my voltage regultor might be bad causing the issue only because when i try to crank it over the starter is only pulling around 6 volts , or am i missing something here??
  • Kster526 said thank you
#34 Leonard VanCamp OFFLINE
Leonard VanCamp
  • 490 Thanks
  • 381 posts
Posted October 23, 2017 - 08:09 PM
The voltage regulator should only affect the voltage coming from the stator. How tight does the starter bendix gear teeth mesh with the teeth on the flywheel? On some of my Kohler motors I had to shim the starter because the teeth meshed too tightly.
  • backwoods said thank you
#35 Trav1s ONLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted October 23, 2017 - 10:42 PM
Likely a bad wire in the harness which get brittle from heat and age.  I went round and round with my 120 - traced continuity, cleaned contacts, and everything else under the sun.  Wiring harness cured the problem.
JD shows the early and later 300 wiring harnesses are still available.
Edited by Trav1s, October 23, 2017 - 10:47 PM.
#36 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted October 24, 2017 - 06:24 AM
Thanks Travis im going to disconnect the drive shaft tonight to see if itll start that way , only because it rolled fine by hand before so the only other thing i was told to check was to see if itll start without the driveshaft connected, if it does something in the driveshaft is binding up.
#37 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted October 25, 2017 - 06:05 AM
Well last nights discoveries uncovered that the pto was binding up so i removed that an i was in the clear once i can get fuel to it it should start right up
  • KennyP, Trav1s and Leonard VanCamp have said thanks
#38 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted October 27, 2017 - 08:29 AM
We have lift off an a tilled in garden now
  • KennyP, hdg4400 and Leonard VanCamp have said thanks
