PTO warning light wiring and pigtail location
wards pto warning light wiring clamp
4 replies to this topic
#1 ktznz OFFLINE
ktznz
  • 64 Thanks
  • 90 posts
Posted July 30, 2016 - 11:52 PM
Would like to know where the wiring clip on the PTO is supposed to be connected. My pic shows three (3) potential bolt locations such that the spring on the pigtail can be touched by the PTO lever arm when the PTO is pulled back for activation. Thanks.
  • ACmowerguy said thank you
#2 KC9KAS ONLINE
KC9KAS
  • 5,391 Thanks
  • 4,693 posts
Posted July 31, 2016 - 08:46 AM
I think it goes where the nut is in the center of the photo.
The other bolts go into threads affixed to the frame and the clip couldn't be mounted there.
We have a Gilson S-14 and I didn't do a good job of remembering where ours was attached,  but then again, all our PTO business was missing!
  • ktznz said thank you
#3 ktznz OFFLINE
ktznz
  • 64 Thanks
  • 90 posts
Posted July 31, 2016 - 10:31 AM
Thanks very much. As I was reading your response; the only thing I coud say, and quite loudly was "ddddDDDDDUH!!!"
  • KC9KAS said thank you
#4 ktznz OFFLINE
ktznz
  • 64 Thanks
  • 90 posts
Posted August 03, 2016 - 02:19 PM
KC9KAS, you were correct and I was in luck; the bulb in my warning light works and the mechanism works. yea! ken
#5 ACmowerguy OFFLINE
ACmowerguy
  • 428 Thanks
  • 372 posts
Posted January 11, 2017 - 08:02 PM
I am in the process of reassembling the dash on my MW and was unsure where to attach the wire. This posting did just the trick. Thank you.
Also tagged with one or more of these keywords: wards, pto, warning light, wiring clamp
