John Deere 990
4 replies to this topic
#1 Lamarops OFFLINE
Lamarops
  • 1 Thanks
  • 1 posts
Posted July 29, 2016 - 09:21 PM
My ID 990 will only move in low gear, I changed the fluid and replaced the first and no luck. The engine runs fine and the bucket moves without any trouble. I need help.
  • tomgo1 said thank you
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted July 29, 2016 - 09:51 PM
To clarify, do you only have first gear in all three ranges, or just the low range gears?
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted July 30, 2016 - 07:58 AM
:welcometogttalk: Same question as above
#4 EricFromPa ONLINE
EricFromPa
  • 3,524 Thanks
  • 3,070 posts
Posted July 30, 2016 - 02:20 PM
If it will only move in low range you might have a broken range selector shift fork.From what I've read it's a fairly common problem.Will it move in 1st and reverse gear in the other 2 ranges?
If it will only move in 1st gear low range and not moving in 2nd and 3rd and won't move at all in higher range in any gear then it sounds like you might have problems with the pressure plate and/or clutch.Which really sucks.You can get reman clutch and pressure plate for around $550.But if you just need the clutch disk it's around $100.
Ebay is actually a good place to check for stuff like that.
http://www.ebay.com/...clutch&_sacat=0
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted August 13, 2016 - 02:29 PM
Hard to help someone when they disappear
