126 drive shaft removal
8 replies to this topic
#1 apc237 OFFLINE
apc237
  • 7 Thanks
  • 15 posts
Posted July 29, 2016 - 08:02 PM
Anyone have a trick for taking out the roll pins that hold the driveshaft to the rearend on a 126, mine won't move now mater hiw hard I smack it
  • chieffan said thank you
#2 chieffan ONLINE
  • 10,119 Thanks
  • 6,625 posts
Posted July 29, 2016 - 08:55 PM
Lot of soaking with PB Blaster and time.  Also need the right size punch so your not spreading the rolling pin by driving the punch into it.
#3 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted July 29, 2016 - 09:31 PM
The previous comment is dead on, only a special roll pin punch with the dimple on the top makes the job so much easier!
#4 olds45512 OFFLINE
olds45512
  • 1,339 Thanks
  • 677 posts
Posted July 29, 2016 - 09:52 PM
i use a roll pin bit in an air hammer, even the really stuck pins don't stand a chance.
  • stiemmy said thank you
#5 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted July 29, 2016 - 10:58 PM
Thats a great idea!
May want to post that tip in restoration tips n tricks section? ;)
#6 secondtry OFFLINE
secondtry
  • 1,866 Thanks
  • 1,374 posts
Posted July 29, 2016 - 11:49 PM
where are such bits available, how expensive, I would think it would require a set almost as extensive as a drill bit set. I have 3 pin punch sets and still never seem to have the correct size.   Don
#7 EricFromPa ONLINE
EricFromPa
  • 3,649 Thanks
  • 3,109 posts
Posted July 30, 2016 - 02:15 AM
Here ya go and it's for 1/4" roll pins.I gota get 1 of these myself,looks like it could be a really handy tool.
AJX-A1102 1/4" #8 shank roll pin driver
http://www.coastalto.../AJX-A1102.html
Edited by EricFromPa, July 30, 2016 - 02:24 AM.
#8 secondtry OFFLINE
secondtry
  • 1,866 Thanks
  • 1,374 posts
Posted July 30, 2016 - 10:18 AM
    The day it arrived at my home I would have 10 3/16 pins to remove. Ordering and buying one at a time I could see spending 100$ and still coming up way short. Don
#9 apc237 OFFLINE
apc237
  • 7 Thanks
  • 15 posts
Posted July 30, 2016 - 05:11 PM
Thanks for the info everyone, lpb blaster and heat worked.
