Potato plow change. Pictures.
6 replies to this topic
#1 propane1 ONLINE
propane1
  • 9,120 Thanks
  • 4,275 posts
Posted July 29, 2016 - 06:31 PM
I am adapting the potatoe plow I rigged up last year for one of my garden tractors to fit on to the ferguson tractor. It's quick attach to the ferguson and then still can be removed and used on the garden tractor. I am going to make the plow part a little wider also. I like using many tractors for the same task, just to see the difference. Plus my potatoe hills are taller this year and the garden tractor will not clear the row. Even the ferguson will be close or be touching. Any way we will see what happens.
Noel
  • DH1, LPBolens, Alc and 7 others have said thanks
#2 KennyP ONLINE
  • 40,089 Thanks
  • 46,752 posts
Posted July 29, 2016 - 06:36 PM
Good luck!
  • propane1 said thank you
#3 jimbobbillyray OFFLINE
jimbobbillyray
  • 3,059 Thanks
  • 2,892 posts
Posted July 29, 2016 - 07:05 PM
That should do the trick!
#4 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted July 29, 2016 - 07:18 PM
Looks like that should do the trick :thumbs:
#5 chieffan ONLINE
  • 10,893 Thanks
  • 6,921 posts
Posted July 29, 2016 - 08:50 PM
The potato plows I have seen and used had a wide shovel that had a blunt point and went straight up the sides.  About 14 -16" wide.  They lift the entire width of the growing area that way.  If yours don't lift the potatoes enough you might try the wider full length type shovel.  Good luck.  Digging out 2 - 30' rows tomorrow the old fashioned way - potato fork and pails.
  • stiemmy and propane1 have said thanks
#6 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted July 30, 2016 - 07:53 AM
Better you than me!
#7 KC9KAS ONLINE
KC9KAS
  • 5,443 Thanks
  • 4,710 posts
Posted July 30, 2016 - 08:54 AM
You must be a really big Potato Farmer to need that equipment!
Good luck with your crop!
